I wonder how that would interact with the latching button?
It would be super cool if it could be swapped to a momentary haha I’ve almost left my raceboard on twice now
Wishful thinking I know
I’d happily pull my whole board apart to swap the switch.
We are working on adding this to the design for Solo, as more progress is made will for sure share
But i dont think it will be backwards compatible
The momentary switch support for both the SOLO and LFOC are happening in tandem. And yes it will support both latching and momentary switches. But if you use latching, then you won’t have any auto-shutdown.
Backwards compatible to solo v1 tho?
So nice you are doing something new!!
Specs?
LFOV v4 changes so far:
That’s nice.
Few questions:
Nope. Higher voltage is what the Tronic 250R is for and its getting a similar update
Yeah smart LED control. Dedicated connector and what not.
Yes. Tronic 250R going to 32S operations and having similar upgrades.
Awesome so 250R will be 32s, that’s great!!
Few questions for the tronic:
Thanks Shaman, all these are very good news! thanks for the efforst and great work
So it will be less efficient at 24s compared to 250R v1?
Same amerage values but with cooler operation. Switching over to better MOSFETs since things are coming back in good stock
Yes. The goal is to give it as much capability for OW-type applications as possible. Having Smart LED control also gives the opportunity to support things like blinkers and other lights for other applications
It’s intended. The challenge is on the firmware side.
Same drill pattern and PCB size. I’ve had requests for the large capacitors to be horizontal rather than vertical. The design can support either.
The design work is in progress. Stand by for updates.
Actually no. The MOSFETs i’m switching to are higher voltage AND lower Rds(on). Meaning cooler (more efficient) operation.
I have some more question, will number them for easy reply for you:
I guess the momentary switch will enable auto shutoff, right?
Last question, I guess the Tronic 250R 32s you are talking about, is not the Tronic X12, right? I ask for 2 reasons:
I do hope the more robust light power supply is on the 5v rail.
The 12v LED support is silly in my opinion.
Accessories on the same circuit as my pwm input is scary to me. I want that stuff isolated
Yes the 5V rail can supply up to 2A
No extra PCB. The controller by itself supports smart LED control
It can via the available extra GPIO. The LFOC has always been able to do this
5V Smart LEDs. Ones like the ws2812b.
Yes
250R is not the X12. X12 is something else
Thanks for the patience and reply all the questions.
Tronic 250R 32s with the specs given, is “the ESC” at the moment. Nothing better
How much current can 12V supply?
