This thread is for the good kind of “Oh Shit!” moments, when you learn or figure out a way of doing things that makes life way easier. Making it cheaper is also much appreciated. I’ll start:
How to break a tire bead with cheap tools and no rim/tire damage
Supplies needed:
2x quick release clamps (I used the $3 harbor frieght variety)
windex or equivalent
Procedure:
remove rubber covers from clamp jaws (this gives them a narrower flange that can reach further inside the bead)
apply windex
squeeze a clamp on, as close to the bead as possible, until the jaw is below the rim flange and a little gap opens up
scooch the clamp all the way into the bead
continue clamping
apply windex and second clamp close by
moar squiize
if the bead doesn’t break, take off the first clamp and move one step around the rim
This will not work if you bolt was stripped due to being made from weak metal. If it stripped because you were an idiot with a drill then it is a good solution. If you stripped it with hand tools, then go buy a screw/bolt extractor.
Yup; if it is a weak metal to begin with, turning it into a flat head screw even makes it easier to destroy.
That said, I found that having a torch makes a heap of difference if a bolt is only slightly stripped; i.e. there’s still some bite but it still slips, like with grub screws.
another option, specifically for legal cores, is to drill the holes out with a 15/64th bit. a lot of times there are mold seams in the holes or other imperfections that grab the pins harder.
I’m sure this works, but if I try to buy a drill bit with such an absurd unit of measurement on it, i run the risk of passing out before i reach the checkout.
Bruh
LHB’s tip is perfectly welcome, I just hate that my country foists so many uncommon denominators on me. Shoulda used a joke that made that more clear, sorry @longhairedboy
When I want some greens without making a full salad, Ive gone to make salad sliders for my mouth hole(SSFMH).
Shove some greens in there, toss some sunflower seeds, top it off with bacon bits and some dressing and boom salad slider.
This has been going on for a couple years and isn’t going to stop. I have saved at least a few loads in the dish washer.
Every Californian should do this during their droughts.
