I don’t have a competitive board to race with, blah blah sciency shit is all I have left. Please ![]()
let’s see what you can still get!
this is all about pushing your skills, getting better, and gaining a deeper insight on how you can tune your board better ![]()
you can do it.
@poastoast did it on every board he could get his hands on.
@ShutterShock is doing it with every production board he reviews.
Stooge RaceBoards v5.
2wd
castle xlx2
560kv Hobbywing 70125 motors
8s3p lipo. ( 6x 4s 10Ah lipos )
14/78 gearing
50A duro SRB/BRP tires.
215lbs rider + gear.
48mph gearing.
Yeah, the only way I’ve found to improve this a bit is to use an app that has an accelerometer built in to measure acceleration instead of relying on GPS. Some phone “dyno” apps are shockingly good for what they are. also, I think that metr is 3hz so if you have a properly calibrated setup you can get a pretty good reading.
i added you in ![]()
and oh man is it an experience!
it was a hlast trying everyone’s boards (tho next time 8’ll make sire to have all the logs properly labeled and screnshot before i lose my phone ![]()
We racing for pinks ![]()
shit ![]()
i’d lose immediately!
With low tire pressure, thick sidewalls, and a sticky surface, the laws of physics might surprise you.
Not sure how to stay on top of the board, though. Maybe just fall forward and punch the throttle before your face hits the ground?
And all of the tires you tested on were softer than your RS rocks, maybe if you had soft tires on your board or BRP you could have more traction?
Also these are my 100m times. Please update when u can
You can leave off the others but the 14s raceboard deserves a spot. Not sure what happened with Chris’s time, seems awfully long
I may be able to test on Friday
Nvm not on android
i think it’s partially due to my ramp time and current settings
i think at time of my testing i got 50A per side? really not much
i think 1/8 miles is uhhh 200m sprint ![]()
Right lol idk how he even found a space that long - but you’re right that’s 200m ish
Tractor pull too. Cause ya know, my necks red.
bruh, Usain Bolt is only barely slower than exway atlas pro ![]()
That’s crazy to think about ![]()
