Alrighty tighty!
DRAG RACING!
Let’s see how fast you can do 0-20, 0-30, 100m dash, anything you’d like to show off your board!
- some basic rules
1ft rollout is NOT allowed, so no dick measuring from the cheeks
please use the flatest ground you can run, let’s try to keep it keep it below 3% grade!
of course, be safe! I’m not responsible if you go fast and eat ass!
using a dragy or racebox (racebox is better) will help improve your accuracy! It is NOT required tho! so long as you can prove your times!
post whatever metric you wanna share, your times, slopes if possible, logs, power output, all the good stuff!
0-20 LEADERBOARD
| place | time | split | board | who |
| 0.94 | +0.00 | Stoog? | @R2trivv | |
| 0.99 | +0.05 | stop resisting | @poastoast | |
| 1.01 | +0.07 | Stoogenetic | @zero_ads | |
| • __ • | 1.04 | +0.10 | Nyan Cat | @SquishyCat |
| • __ • | 1.06 | +0.12 | Archangel | @Ash |
| • __ • | 1.08 | +0.14 | lmao topmount | @HAIRYMANJACK |
| • __ • | 1.09 | +0.15 | RaceBro | @Dinnye |
| • __ • | 1.17 | +0.23 | Stooge V5 | @fessyfoo |
| • __ • | 1.21 | +0.27 | Ankle Wreacher | @tuckjohn |
| • __ • | 1.27 | +0.35 | zoomi boi | @Shadowfax |
| • __ • | 1.34 | +0.40 | Brady Cruiser V1 | @TZDKB |
| • __ • | 1.36 | +0.42 | Downside Up | @JeffyJ |
| • __ • | 1.40 | +0.46 | RallyBro | @Yeahthatperson |
| • __ • | 1.42 | +0.48 | antarctic | @ARCTIC |
| • __ • | 1.48 | +0.54 | _____ | @Tasventouras |
| • __ • | 1.48 | +0.54 | Roci | @jack.luis |
| • __ • | 1.54 | +0.60 | Inazuma | @ShutterShock |
| • __ • | 1.55 | +0.61 | Bao | Bao? |
| • __ • | 1.56 | +0.62 | Mach 1 proto | @Tony_Stark |
| • __ • | 1.57 | +0.63 | 100mph magnetic | @Skyart |
| • __ • | 1.58 | +0.64 | Can Traction | @Dinnye |
| • __ • | 1.59 | +0.65 | Raijin Blade | @sugandese |
| • __ • | 1.66 | +0.72 | Squall 1 | @Evwan |
| • __ • | 1.67 | +0.73 | 120 A Tabor | Hoyt |
| • __ • | 1.79 | +0.85 | Magnetic R | @Skyart |
| • __ • | 1.84 | +0.90 | Pete’s Board | Pete |
| • __ • | ~1.9 | +0.96 | Cute | @Heathlewis |
| • __ • | 1.91 | +0.97 | ________ | @Goride65 |
| • __ • | 1.95 | +1.01 | lacrocs | @Shadowfax |
0-30 LEADERBOARD
| place | time | split | what | who |
| 1.59 | +0.00 | Stoog? | @R2trivv | |
| 1.64 | +0.05 | lmao topmount | @HAIRYMANJACK | |
| 1.66 | +0.07 | Archangel | @Ash | |
| • __ • | 1.68 | +0.09 | Stop Resisting | @poastoast |
| • __ • | 1.71 | +0.12 | DemonGeese | @zero_ads |
| • __ • | 1.85 | +0.26 | Ankle Wreacher | @tuckjohn |
| • __ • | 1.86 | +0.28 | Stooge? | @fessyfoo |
| • __ • | 2.05 | +0.46 | Nyan Cat | @SquishyCat |
| • __ • | 2.18 | +0.59 | RallyBro | @Yeahthatperson |
| • __ • | 2.21 | +0.62 | Downside Up | @JeffyJ |
| • __ • | 2.26 | +0.67 | Antacric | @ARCTIC |
| • __ • | 2.29 | +0.70 | _____ | @Tasventouras |
| • __ • | 2.58 | +0.99 | Nyan Cat | @SquishyCat |
| • __ • | ~2.6 | +1.01 | Cute | @Heathlewis |
| • __ • | 2.60 | +1.01 | Mach 1 proto | @Tony_Stark |
| • __ • | 2.62 | +1.03 | Raijin blade | @sugandese |
| • __ • | 2.90 | +1.31 | ________ | @Goride65 |
| • __ • | 3.64 | +2.05 | Inazuma | @ShutterShock |
0-40 LEADERBOARD
| 2.27 | +0.00 | Stoog | @R2trivv | |
| 2.36 | +0.09 | Archangel | @Ash | |
| 2.44 | +0.17 | Ankle Wreacher | @tuckjohn | |
| • __ • | 2.61 | +0.34 | DemonGeese | @zero_ads |
| • __ • | 3.34 | +1.07 | stoog | @fessyfoo |
| • __ • | 3.57 | +1.30 | stoog | Bwandon |
| • __ • | 3.73 | +1.46 | Downside Up | @JeffyJ |
| • __ • | 3.77 | +1.50 | Stop Resisting | @poastoast |
| • __ • | ~3.8 | +1.53 | Cute | @Heathlewis |
| • __ • | 4.87 | +2.60 | ________ | @Goride65 |
100m LEADERBOARD
| 6.10 | +0.00 | DemonGeese | @zero_ads | |
| 6.72 | +0.62 | stooge V5 | @fessyfoo | |
| 6.82 | +0.72 | Stop Resisting | @poastoast | |
| • __ • | 7.25 | +1.15 | VESC™ based board |
@JeffyJ |
| • __ • | 8.09 | +1.99 | P1 | @ShutterShock |
| • __ • | 8.52 | +2.42 | Nyan Cat | @SquishyCat |
| • __ • | 10.12 | +4.02 | Raijin blade | @sugandese |
| • __ • | 12.58 | +6.48 | RallyBro | @Yeahthatperson |
| • __ • | 13.50 | +7.80 | RaceBro | @Dinnye |
| • __ • | 13.90 | +7.80 | RaceBro | @Dinnye |
