Hi Remieknaapen, have you been able to upload the tire adapters? Thanks!
Hi,
Sorry, itās taking a bit longer because i was away for the weekend.
I will get to it tonight and post it over here!
Here it is: PeiPei phub-188 Onewheel pint tire adaptor by RK_design - Thingiverse
Please leave a comment on thingiverse if it works out for you!
Thank you, especially for the step file! Donāt have my phub-188 yet but going to get working on getting a couple of these printed out. Will share any edits I make.
I have my Burris 11x6-6 treaded tire and at rest the outer edges of the tire bead measure 180mm.
I wonder if these would fit any onewheel pint accessories like their fenders or mini fangs.
My plan is to get some small 40x18mm wheels for fangs and modify the printed nose piece from Enginir to incorporate them. Can share the modified model when I get around to it if Enginir is okay with that.
Yes please
Oi oi I spy mine in there
Just received order Everything looks fine and cool. Thank U for your quick replies and answers.
Mine is still saying on the tracking shipping information received, doesnāt say they have it or anything
Same. I think itās that way until it lands in your country and DHL picks it locally
I hope so. Not like Iām in a rush. But I want to get customizing the rails and stuff before I order the hub
HK is busy these days, we are waiting in line for flights but i heard that most of the orders are on flight today, should be 2-3 days after DHL pick up
I got shipping confirmation today and will be delivered Wednesday
My kit started moving today with a projected delivery of next Friday the 26th. My phub-188 finally has a tracking number but it hasnāt started moving yet.
I started working on modifying the nose and tail parts. For the nose, I am incorporating small wheels (fangs). The wheels came in today so going to make a CAD model of them and start playing around with it. For the tail, not modifying much other than adding some holes to the rear to insert threaded nut inserts. Then will model some simple plastic plates I can screw in that will be sacrificial material for those grinding stops.
Another thought that is floating around in my head, are printed plastic bumpers on the sides of the rails. Could make it as an L bracket that gets sandwiched between the bottom plate and the rail. The added benefit is that it would lower the bottom plate and might give me more room for a 12s2p 40T battery pack. Going to wait till I get my frame kit so I can make some measurements.
great job bro
I only found this thread 2 days ago and have been reading it constantly sinceā¦ What an incredible job - mad props to you for it.
Your website seems to suggest the kit was a one time thingā¦have I totally missed it?!
sorry they are sold out now bruh XD
Sad face! Will anything convince you to make more?
