Hello
just nearing completion of by board just wondering if anybody has used leds on their builds? if so can i possible see them please have a few ideas but im sure there aree better ones out there
thanks
Shredlights to see ahead
Arduino strips for looks
Can confirm, @Ricco makes a great module
was thinking of flashing red led on the rear like in f1
The TTL had a rear light and front light implementation (horn too). It ties in to your uart and you can program it to flash, brighten, etc when it senses the remote braking.
I also use an xlite 100 which is battery powered and has an accelerometer inside so when I brake it turns on automatically. It’s not 100% accurate but does the job and has standard strobe, fade, etc modes.
that looks perfect hope it isnt too much
thanks
3d printed spacer for dickyho mount, esp8266 connected to flipsky reciever uart.
Hi could you please send me the file getting a printer soon thank you
Can’t see anything?
hello can you please post that vid again thanks
Now you can download it and watch.
Wondering if @Ricco ‘s module would be compatible with my led stuff.
Tell me more!
Just have some leds under my board atm, but I’ve made it so it’s modular and I can add whatever to it if I choose. Though wondering if I can just attach Ricco’s module to it?
The TTL contol module can control 12v analog RGB strips or 5v APA102 based addressable strips. It looks like your strips are analog. If they are 12v, they would be able be attached to the module no problem.
Oh sweet.
