if i really was any smart, i’d be in a position to afford to make expensive mistakes
Started working on series connections, pack should be done by saturday morning, work was kinda crazy today, and will probbaly be tommorow too.
All this talk of 13s and you ended up doing a 12s? I have a 13s5p with samsung 25r’s on one of my mountain boards. Works just fine
I also have a Falcon 40 evo with the DS enclosure and 12s8p 40T cells (and external bms) and the berg rims and 6x2’s with avio mkII gear drives. These subsonic decks are awesome! I’m ordering a century 40 and making a 12s4p 40t single stack to go with a set of moon drives for my next board. I am considering putting some huge urethane wheels on the century though, 105mm or 110mm.
When you have your bergs mounted, can you please measure ground clearance from the bottom of the enclosure to a level surface and take pics from the lowest points of clearance? I don’t have my deck yet and I am still not certain how much riser I’m going to need.
will do! yeah definitely get at least 1/2" worth of risers if you plan on going thane, but clearance is not as bad as everyone is making it seem, unless you are rolling over the really small and tall bumps in a parking lot, you shouldn’t have a problem even on thane. having said that i recommend riptide tunnel riser for the back and a 3/8 to a 1/2 riser in front, and definitely 110s
Havnt been able to do much in a few days, but back at it! Going to finish the battery tonight. Also I set up my new work area! I have alot more building space now woooot!
Just 5 more series sonnebtuons to make then I can work on balance wires and main positive and negative
Will be fishpapering this bad boy now
Black cherry whiteclaw + ice + 3 shots of vodka
TBH feels like I am wasting good vodka…bought white claw cause bbgurl was curious about it…she is no longer curious
Just charge left!
Clear shrink wrap is such a win @Mr_Monday clean shrink wrap! Your battery is next bro!
Ok, almost done! Motor detection passed,
Settings are
80 amp motor
-55 break
150 absolute max
80 batt
-20 Regen
Loop key installed, everything is gtg, just waiting in the gasket, should be here wednsday! Wooot! Going to take it on a test spin tommorow.
i must have missed it, what wheels, pulleys, and motor mounts are those?
Looks like TB Cnc trucks with TB mounts, not sure on wheels though
BN trucks and mounts, Bergs, 6x2 tires. the front truck will be changed out to BN. was too lazy last night lol. going to give it a test spin after the battery charges. motors are 6374 maytech.
BN
Jk man. She looks
before you take the tb cnc trucks off, i’m curious: with everything mounted, is there any play in your pivot cups like @CiscoV’s tb cnc trucks?
I think that’s been fixed since. I’m still holding my breath and hoping that @torqueboards will eventually replace all 4 baseplates that I have ![]()
No there is not because I sent those guys to him. Mine come play freeee. No slop no nothing.
I can send you Baseplates brotha I think I have 4 of the new versions.
EDIT: correction I only found 3 the 4th is hiding.
