Landyachtz EVO | 12s4p | TB DirectDrive 75kv|Unity| ABEC 97mm Clones
no I designed and made in aluminium on the CNC. I can see if I still have it somewhere the file :grin:
amazing thanks! curious, how does the underside look?
you can check my Thanos build. You do not see anything, I fix the deck under the cnc and made the a little pocket for the cables so they come out from the truck. the base plate covers the cable and the underneath of the button and charge port. They then run together with the motor phase leads.
