LACROIX Stormcore ESC and iOS app info
Im gonna have to figure out how to do that haha thats definitely alien territory for me. Definitely worth a shot! Im a sucker for bldc
The ONLY reason I stopped using BLDC is because HFI doesn’t support it. I do like BLDC mode a lot.
Same here (i love it too). Its just quite daunting to not use the wizard and go full manual.
By the way, when you mean manual motor detection you mean this page right? (But BLDC selected of course) Because i have tried using this before, but no matter what i did, the motor would only spin up and shortly after it would give a bad detection received message
Does anybody know if this Battery output on 60D+ is directly connected to the bat + and - or only while the stormcore is on?
Only when stormcore is on
Can someone give me a definite answer what is a correct way to connect 2 stormcores 60d+ via CAN as master/slave so I can use only one switch to power both…
I have seen numerous answers to this topic across this forum…
  • Do not connect GND
  • Add resistor in line of 5V
  • Connect all pins
Just a few of solutions seen here
Also some users have difficulty with making this work at all… So what is a definite answer for 2 stormcores in 4WD boards scenario?
@Arch @Deodand @Blasto are you guys still around?
I can tell ya when I get home. Or @Skyart can tell ya off hand.
Just a reminder. Thanks a lot :grimacing:
