Dear @Deodand and @Blasto,
First of all hard to read these kind of stories and I wish all the best for you and that everything turns out to the most beneficial way for you.
For now, I‘d highly appreciate your help:
I own a Raptor 2.0 with broken foxholes through water injections.
Since my skills here are very limited I want to replace them easily with your astonishing looking Stormcore (60D) and a related remote. Will this work out? As far as I‘d understood I‘d need to insert a fitting configuration via the tooling to prevent the Motors from overheating. But for me as a programmer this does not seem to be impossible.
Is there something like a preset available? Or is there some kind of instruction in place?
I am sure this was covered somewhere. But what do I need to do if I want to use a loopkey to power my stormcore? Do I simply make a jumper between BTN and BTN?
for dual stormcores, (quad esc) i would use the CAN bus. Use one single button, connect the CAN bus in between them using 3 of the 4 pins (5V,CANH, CANL) no gnd.
Then configure using the setup wizard, it will automatically find the other Stormcore on the CAN bus and config it as well in a master-slave fashion.
Then you will be able to turn on and shutdown both SC using a single button.
Sooooo uuum whats a 60D+…? And how is it dif from the 60D? Does it finally have the uart ports I’ve been wanting oh so badly when is the 100D+ coming along? @Deodand@Blasto
