LACROIX Stormcore ESC and iOS app info
Will do, thanks for the heads up
It’s all good, honest unbiased feedback is appreciated. If I had a definitive answer on what does and doesn’t work it would be shared but it’s too early in the process to know which setups will work well and which won’t. For instance the boosted scooter hub motors seem to work well all the way up to 20s, Rion’s didn’t play nice and it sounds like you are having some issues as well.
If you wanted to share the motor properties I might be able to help you tweak some parameters to dial the motors in better. Looking at the faults reported it looks like the observer might be losing track. There is some implicit scaling with source voltage in the observer gain scheduling that Ben and I have been looking at and might still need some tweaking. Have you tried playing with these Enum settings under advanced:
In particular sometimes the iterative observer seems to do a bit better with some motors.
If you throttle it up with the wheels in the air and jam the throttle on/off repeatedly does the issue surface?
@Arch Any thoughts on releasing a “Stormcore 60/100D PLUS” in the next year?
oh look at this nice draft sitting here.
What for? A.S.S. ?
add another male xt90 for no reason. $200 Rebanded Puck Puck Bruce remotes bundeled for $100
Who has successfully ran 16s on regular 6374/6380 motors?
I think @Sender had done 15s not sure if anyonebhas done higher. I am currently building an 18s battery for @ahrav i think he will be using 190kv TB motors on that voltage
6380 or 63100?
Them bearings are going to have to work overtime :grimacing:
I can hear them crying already
Dope, imma be running 16s 170kv TB
18s 4x6374
Have worked great for 10 month now without any problems!
are those hypertrucks in the back?
Its 3dservisas FatBoy hangers and adjustable cnc made baseplate. Cant remember who made the baseplate but it was somone on this forum.
Riptide bushings.
Edit:Ah yea I se now in the back. Yes I did a repair on a Nazare for a friend at that time picture was taken.
63100s. Running them at 14s has been a game changer :eyes:
Let’s see how 18s does.
@Blasto @Deodand
I and few others have asked this few times already…
Could we get some info about when the second uart port will be enabled on Stormies?
How is the torque of the 10x with stormcore ? Are the motors able to handle the amps?
I have a 16s build on 4:1 Kaly helicals and 140kv MT motors coming up. I really hope I’m within an expected use case @Deodand
Im also keenly waiting on this update.
It will not work with any firmware update sadly.
Dont worry, it will work.
