Amen brother. ESN was fucking borne of outrage, dissent and melodrama. Blessed be the naysayer, but our newly resident Acedeck shill has yet to bring anything of any interest or value.
@DerelictRobot - help me understand those mounts. The single bolt on the backside locks/unlocks the tensioner. The larger bolt protruding from the bottom of the mount adds or releases tension. Is there any spring involved now?
Yes, yes, yes. You got it. Single bolt in in the side locks in the maximum CTC distance and then the mega-grub fine tunes the spring tension. Here’s it with the single bolt opened up:
Pretty slick design - I put it up there with the Hoyt motor mounts in terms of quality/usefulness.
That’s pretty sick, I could imagine that making belts last longer too if you got a pebble stuck in the belt, maybe the spring would absorb the additional tension and keep the belt from insta snapping
I believe the spring only sets initial tension, then you lock the mount with the side bolt. Otherwise, you’d have massive belt skipping on acceleration and braking.
It would be pretty cool if there was a secondary spring with a very high spring rate that only compressed when something was lodged in the belt, but I’m not sure how doable that is with the torque we apply to these things
I’d imagine the order is: tension spring, set motor mount with side-bolt while assembled for baseline, fine tune spring tension. nope @MacKeeper28 was correct initially.
Unfortunately these have been paperweights until very recently because I’m a terrible tester
Nope, I was wrong- actually you had it correct the first time. I just went through and tightened everything up.
It’s tension spring first, then lock it into place with a single bolt.
I was under the impression the spring tensioning allowed small amount of play, but that bolt locks everything firmly into place. Things I would know had I bothered to install these before chiming in with assumption. Ha
