The only thing I would say is that I was running 2 x 75C graphenes in parallel and it started causing trouble w my welder. If u look above, I ended up popping my fuse durinng calibration. Moved back to using 1 at a time at the advice of the guy who sells the units in N. America and the problems resolved themselves. He said it’s too much power for the system. I know others run 2 lipos in parallel successfully but that was my experience.
Okay, thanks for your feedback. I’m just trying to weld .2mm nickel for a 10s3p pack, so nothing too crazy at the moment. I keep reading that one turnigy nano is not enough, but one panther is and so I thought two turnigy nano’s in parellel might be enough power. At the moment I like the idea of trying my car battery, that will allow me to continue with the project and wait for the turnigy panthers to restock.
I run 2x6Ah graphines started at 1800A but the battery’s have degraded and now down to 1500A. Thay could have updated the battery’s and might be able to deliver more now or you had realy good ones🤷♂️
heya, I just wanted to document my experience with my kweld and the setup I’ve gone with.
For starters, my current setup is 2x 4ah 3s turnigy “heavy duty” lipos. It works great and the probes get hot before anything else. @jack.luis made a nice dual xt90 to QS8 connector for me to hook up both lipos without any bottlnecks. The lipos and the wires stay nice and cool after an entire P group. With the 5ah variant of these lipos, it actually went over current and read over 2000 amps, but with the 4ah version it seems fine. On 0.2mm nickel I’m getting consistent welds at 42J.
my kweld managed to blow my 3s 5ah turnigy graphene. I wouldnt recommend a single graphene as the 10awg wires and xt90 cant handle all of the current and will get very hot.
After lot of tinkering and a little help from @glyphiks and @rusins here’s my setup and settings:
Battery: P42A
Nickel: NKON 0.20mm 30mm nickel
Power source: single Nano-Tech 5Ah 3s pack
Spoweld power: 55J top side, 57J bottom side
I could do about 12 spot welds before taking 10minute break to cool down battery and the leads, with active cooling could probably do entire P-group in one sitting. Popper pressure application (a little, but not too much) makes spotwelds a lot tougher, it’s also good to clean leads after every P group to get perfect welds.
Yeah, cleaning the leads with a bit of sandpaper after a few welds or so is key to getting good results. Did you use isoprop to clean your cells and nickel before welding btw? Just wondering how important it is or not…
I got good results without isopropanol though I bet I wouldve had even better results with it, had propper nickel tearring right at 55J though I suggest checking how well it sticks, Next time I would do this I would make tiny adjustments on the fly based on the welds. Didn’t had any cells destroyed, and even testing cell is still usable, however I did experience one burn through of nickel due to bad contact between nickel and battery surface. It was on + end so it was ok.
Output not input if you connect kcapps to a lipo the super caps will suck several thousand amps. The old ones if thay don’t kill you battry first caps will explode.
