Ok so i got a new battery, just about to set up my new kweld and modify my old one to suit.
Will there be any issues having them both connected at the same time?
Also, does it matter that my positive and negative leads are different lengths? (Assuming that each connector is specific to one kweld)
Edit: got them both running, all seems good! Still curious if there is any potential for damage if running them both at the same time.
Also learned a neat little trick from the user manual
if you start the kweld with the footswitch pressed or the wires shorted, it starts and stays in Auto mode!
