Gonna use this thread to document any strange esk8 experiments I do. So you can learn from my insanity.
Today, we’re running mismatched wheels, and fucking around with ramping times and throttle curves.
Turns out 20 second negative ramping time feels weeeeeird. Who’d have guessed? I believe @Venom121212 described it as “peanut butter throttle” which is accurate. I don’t think the vesc is actually doing 20s negative ramp. In practice, it feels more like maybe 8 seconds of uneven deceleration. And it fucks with my brakes. I can stop on a dime, still, due to .2s positive ramping, but, I can’t let OFF the brakes immediately.
I also put flash 5 inch airless wheels on the front end with Hoyt 5 inch pneumatics in the back. I’ll update with how it affects range when I figure that out. I don’t see it having much effect, though, as they aren’t the drive wheels. Ride feel wise, love it. Doesn’t get caught and spin out in the grass at all anymore. Definitely more comfortable. Eats up bumps that’d shake me a little before. Corners great. And I think it looks pretty ok, too.
Also on the menu this week: tried bleaching some PU wheels. Nothing happened. Gonna try again with less water added. Also, gonna see if unicorn spit works to stain PU. It seems to work on damn near anything. Gotta finish up some work on an enclosure I chopped up and glued back together at the size I needed as well, and attempt a couple Hoyt puck mods I’ve had on my mind(no details, you’ll see) plus do some finish work on the poastmote shell.
Oh, and I’m gonna add extra springs to the triggers on my maytech, if I can figure out how when I open it up. I want dat high tension trigger.
Extra tension on the gas trigger: excellent. But I moved the spring, and added a piece of a zip tie inside it as a guide. Forgot to take a pic while it was open.
I ripped the other one off. Not enough space. Was limited to 65% and also made an annoying noise.
Next: messing with the puck!
Unicorn spit on polyurethane: does not stain. However, it does soak into every tiny crack, allowing you to see EXACTLY how damaged your wheels are. Pretty cool. Can immediately tell that this wheel was about to chunk out, actually.
Currently have a brand new rubber tire sitting in pure bleach. This should, in theory, soften the rubber. Or destroy it. We’ll see. Will compare when I pull it out tomorrow.
Also, currently reading up on anodization. Seems easy enough actually, but I’m not willing to drop cash on the supplies right now. It’s like $600 for a full kit, or $300 if you shop around some for everything. But, definitely interested, as a it would be more cost effective. Maybe some day.
That sounds like it’d be far simpler to do purely as software. Would be cool, though.
I’ve been pretty interested in motor assisted turns(as in, spinning the wheels on the outside of your turn faster) for a while, but haven’t a clue how to implement it.
