Finally I have all parts together to finish this build which is not meant for riding. A lot of them are spare parts from my MTB and urban carver which I already had plus bought the missing parts to make a complete build. The focus was to keep it as light as possible. I might (or need to) change single parts every now and then because of destruction. So here the initial setup
Board only (weight: 7.5 kg / 16.5 lb):
Urban carver deck 14ply
ATB Vertigo trucks
Superstar wheels
MBS T3 tires
Trampa bindings & heelstraps
Mechanics (weight: 0.58 kg / 1.28 lb):
Unik motor mounts
14T motor steel pulleys
ABS 62T wheel pulleys
15mm belts
Electronics, motors & battery (weight: 3.3 kg / 7.28 lb):
Flipsky V4.12
Modified 6364 150kv motors
3x4s 30C 5Ah Zippy lipos
12s BMS 60A (120A peak)
Wires & enclosure (weight: tba)
Final weight approx. 12kg / 26.5 lb
This deck is cracked because of an accident with my urban carver in skate park and glued with epoxy. Hopefully it won’t break apart and if then at least with style. I flipped the deck so the crack is on the rear, should be safer.
Possibly the 14ply is too flexy, with the 16ply HolyPro I bottom out already when landing.
I drilled holes for bindings with this cardboard template, the center line helped a lot.
For true running pulleys I use different slim washers between spacer nut and pulley, works very nice. HK sells washer sets with a range from 0.05mm-0.3mm thickness.
Initially I wanted to use 6355 motors (and save 0.3kg) but then decided for 6364 for a little more power.
There were some loose windings so I glued them and also filled the gaps between the magnets.
Covered the connections on the hall sensor PCB with silicone for electronics.
When I ordered the motors I thought these have 12AWG phase wires but unfortunately it’s not. It’s the end of the windings covered in shrink tube, stiff AF
I read terrible things about solder windings because of the enamel coating so I decided to desolder the 4mm bullets and extend them from this point. It was really strange and almost impossible to desolder. With pliers and 100W iron it worked, not funny at all but I managed to solder silicone wire extensions.
That’s it for now, more progress soon…
just sanded down a bit and filled with epoxy glue. I don’t feel 100% comfortable with the crack but am also curious if I can enlarge or break it. At least I would have a reason to buy a new deck.
Can’t claim it twice if it breaks
