Channel trucks are not meant to go fast, you want really stuff urethane eggs if you do, and if you’re a heavy rider you’re more likely to wobble but if you’re well equipped you can try
Definitely get rid of the springs. The trucks are fine with barrels. I swapped just the front to barrels. It’s pretty right but with the right tuning it’s achievable
Most stable I’ve ever ridden was on @ahravs board. Hit 45 or something like that. Maybe follow his setup of you got the need
Well i’ve myself hot a carver with the mini trucks also have 6374’s, i miss the motor mounts but i doubt that you’ll be able to fit 6374’s on anything else than the trampa carver mounts. You should definitely NOT get the mini ones, i go downhill on it in my town hit about barelly 20 miles per hour and it ain’t that stable (i’m a noob tho so maybe thats why) if you want mini trucks tho i’d happily sell mine to you lol
I haven’t bought anything yet, so I could use pretty much anything. I forgot to mention it in the post but I’m planning to use the Trampa barrels. I’m pretty new to all of this - is there a better option?
Well. Things might be a little different now with new barrels. I mean. I assume they’re close to mbs matrix 2 in stability Right. But as stated above. There are better ways to achieve 40mph without feeling the sketchiness of channel trucks lol
@Agressivstreetlamp are you running full size trucks or the minis? Also @ZachTetra this isn’t a budget build by any means, but I’m not sure I can stomach $900 trucks lol
One of the main reasons I chose to go with the mtb trampa deck and trucks is that I wanted to be able to install bindings and jump things - Do people do that with street decks like the GT40 too?
