The InfinitySink top mount box allows you to mount your escs and heatsink on top of your board with style. With different colors and materials, you can customize the aesthetic of your build.
You can choose between colored filaments, or a stronger, higher quality carbon filled nylon.
Top Mount Box for InfinitySink comes with the following:
Printed Plastic Box
Box bottom (black anodized aluminum)
2x 3-hole Cable glands for phase wires
xt60 and xt90 bracket for battery port
2x grommets for sensor wires
All necessary screws
I want to drop vesc6 at some point so that I can do all m3 countersinks instead of counterbores (because vesc6 is m5 I would need at minimum a 3.5mm mounting plate, way too thick). The benefit of this, is that the hole patterns can be considerably more customizable. Won’t have to match the hole in the mounting plate to the counterbore In the fins plate.
As someone who is currently using my Trampa VESC6’s bolted to the plate with M4 screws and nuts, I would request that you still include the mounting pattern, even if it has to be M3, and just inform Trampa VESC6 users they will have to use nuts to hold it on.
M3 is workable, as long as it has the holes haha. Seems like you should be able to get tons more ESC’s on there by going to countersunk screws, so why not keep the Trampa’s?
