1500km Update
I just happen to take the wheels off my, almost 2 year old, first pneumatic board to replace a broken belt. I am amazed how the 3D printed ABS pulley (teeth coated with super glue) looks and fits like it’s new. Even the layer lines are visible after almost 1500km. I had made a detailed post on this on the builder’s forum in August of 2018 and thought it might be of interest to people who would rather spend $80 on pneumatic wheels and not $200 to begin with. I haven’t yet changed the bearing and it seems smooth enough. Also the clever tires last for ever and are mostly flat free, IF YOU FILLET/CHAMFER THE EDGE OF THE RIM WHERE THE VALVE COMES OUT.
Files
Replacement Tires
Replacement tires are very very cheap(~$5 for tire and tube) if you buy from taobao.
Some guy even bought them shipped for $3.8 per set.
link1: https://item.taobao.com/item.htm?spm=a21wu.10013406.0.0.2d29317egeiJ2t&id=558643804538
link2: https://item.taobao.com/item.htm?spm=a21wu.10013406.0.0.2d29317egeiJ2t&id=564165887103
Original Thread Excerpts
What is needed(3D printed Pulley + 3D printed pulley adapter)
- Tire with hub from aliexpress. $69 for a set of 4 (shipping included) https://www.aliexpress.com/item/free-shipping-6X2-tyre-6-Inch-Scooter-Tire-Inner-Tube-Set-Electric-Scooter-Wheel-Chair/32840489792.html
- Three M6 Bolt, 45mm length $7 for 25pcs https://www.mcmaster.com/#91292a143/=1e8wvz4
- 3D printed pulley adapter. See thingivese link.
- 3D printed pulley(Any teeth count from 42 to 60) See thingivese link.
- Trucks $65 should have 8mm shaft with 35mm free length. TB218 will work. products/torqueboards-218mm-trucks
Modified the part to save plastic
How Inexpensive These Actually Are
