It’s bright too. Definitely the strongest light I’ve had for riding.
Yah currently I have a big ass flashlight taped to my remote. It’s a pretty shit solution tbh.
That’s what i was doing
Im always rough with my helmet…
I mean it’s basically a GoPro mount.
That kind of stuff isn’t designed for impact. Vibrations sure. But they’re not designed to be permanent mounts.
As with any of my mounts, if it breaks for any reason at all I will replace it no questions asked free of charge. I am on the streets as much as anyone and I get that esk8 is hard on equipment; i’d never sell something that can either never break (almost impossible) or isn’t backed by a replacement if something goes wrong, which inevitably happens.
Next idea for you to contemplate … How can you get this to mount under the trucks?
I have a davega that will mount where headlights should go. Initial thought was to sacrifice tail light but I don’t want to look backwards to see telemetry either
I already have one! The issue is I am getting a little bit of wheel rub on standard caliber II trucks. Anything wider than a 180mm (10") truck will fit them just fine. You can see the design above way up there for a dual mount setup. They looked killer on my board and do a wonderful job but for standard trucks they are a hair too wide.
Just found it! Nice stuff. What’s the diameter of the flashlight? I have the front cutout of a hummie deck that’s not doing anything. It would be sweet if the light could tuck in there.
I’m hoping the light fits in here
It is not circular unfortunately; but at its largest it is 34mm wide, 37mm tall (with a flat section on the bottom where the clip mounts). It is pretty much a rectangle with curves when viewed from the front. Including the clip mount it is ~60mm tall.
Gonna be pushing back the release to tomorrow mid-day. I am printing out a few of them in different colors. Sorry for the delay
I’m down for some street side mounting. I also have a DaVega.
I third the downess for the street side mounting . I have tb 218s so we’re good. Just like to keep the topside clean.
Well I’ve got a design already good to go if you want to test it out. I posted it earlier in this thread but never posted a picture with it mounted on my board. It looks very good, but like I said it won’t work with 180mm trucks. 218 should have no problem, though, so if you are willing to test something for me we can get that ball rolling.
yeah I’m in the same boat I got TB218s as well buta would be interested in both lights lol
I will gladly test lights but @BigZwatt gets priority
I’d be happy to test them out for you .
Will they fit e-caliber?
If you hit me with the stl for the under mount version, I can test on 200mm Surfrodz rkp as well.
Went out last night analog for a bit.
This is the best ive been able to see while riding.
Helmet lights are a must for me now.
Seems to be holding up well.
I should be able to test on a esk8 tonight. Solved my broken tool issues
