nah, I think the curve of the handle , hand-hole and board would all try an occupy the same space in the universe… you could redesign it… I stole the idea from a guy on builders who won like a BofY sometime in the past
I think the simplest, cheapest, non-evasive, design friendly, most functional carry handle is a paracord handle…
I think I kyped this thought from @Mikenopolis
SHREDLIGHTS MOUNTS WITH HOLES DRILLED IN THEM
no reason I recommend this
secure it under your base plate
design it with bolt holes
use your imagination
this is DIY
What about like a fold-out trolly handle.
like on EUCs
Allow you to have the board at a lower angle especially if you are tall.
As you can see, I found it particularly annoying not having a handle and drilled MASSIVE holes in the kick tail of the board above the parachord handle board
If your truck bolts are long enough, the handle could go from the bottom of the deck and out
good luck in your quest… makin’ kool shit is a lot of the fun!!!
how about something like this mounted to the truck, can also mount lights to it while youre at it
https://www.amazon.com/dp/B08BQZZK4Z/ref=cm_sw_r_cp_apa_i_ggmmFbYRTZNZY
This is very strong. Went through a few iterations until it didn’t need to. Tested in PLA+, PETG. ABS and nylon will also work very well.
rear_trolley_handle_stronger.STL (16.7 MB)
It’s either I make one or something or get rid of this board (people will be mad if I do that) @CiscoV and @DEEIF cause I can’t even lock this thing up on the skateboard locks at school lol…
I already told you a compromise KADE… Anything but a OneWheel…
I made several with the “pyramid” adapter, see here:
Also here:
The left one I had for several hundred miles carrying ~8kg Spud and no issues (printed in PLA)
Interesting! I believe the Metroboard X has something like that? Someone back me up on that lol.
Thats what I have on one of mine, it works great.
