Straight of the esk8 only fans I see.
“Naked DIYer jumping with flexi dick… I mean deck”
What trucks did you use?
Is it a gear or belt drive?
I’m asking because I see the motors facing forward.
The hubs also look nice, they are minimalistic
I have not seen the finished case, only the preparatory work for making the mold, so I do not know what the dimensions of the new enclosure will be, we have to wait for the launch
However, if you want a deep enclosure then you can write to Vikarees, he makes aluminum enclosures for my deck, they are deep and have a large capacity
Do you have his contact info?
I contact him via FB and Instagram
I don’t understand your idea
Draw it for me
I think he’s asking for a drop through mount flex -1
He wants a really stiff deck, and brackets that drop it down even lower for use with a topmount battery.
Do you know when the 2nd version of the enclosure from Alan will be ready? Thanks!
Alan told me that he will make the enclosures in June
New brackets and base plates for Stooge NKP trucks
I also designed an adapter for classic decks, the adapter mounts instead of the bracket.
The adapter and brackets now have inch threads No.10-32
Dang it. Just ordered the other ones. Might have to make* another order.
He told me that it was going to be put up this past weekend but hasn’t been put up yet. I think it’ll be soon tho.
The brackets you ordered are universal, fits many types of trucks.
New brackets with baseplates only fit 3-link axles, their advantage is that you do not need a baseplate.
If you have a complete 3-link truck (axles + baseplate), the bracket you bought earlier is a great option.
Any thoughts about making a longer/wider deck? I would be nice to see a deck and enclosure that could fit a 12s5p single stack.
The second version of the deeper enclosure by eboosted
Don’t ask me about capacity, this question will only be answered by Alan @eboosted
Maybe in some time, sooner I have to sell what I have in stock
If you mount the ESC on a bracket at the back of the board, a single stack of 12S5P will fit inside.
I also designed a bracket for mounting the ESC
That looks nice! On the eBoosted website, looks like it will fit 64 cells, a smart BMS and ESC.
Also looks like the enclosure is pre-drilled and ready to mount to the deck.
More information and dimensions are already published on the eboosted website
