Photos requested
How are your motors? Are they forward or rear of the wheels?
Photos requested
forward
I dont know what trucks you are using, but other then that you basically have the same drive train setup (mine is single)
bn220, bn motor mounts, 6368 motors, caguamas
I have caliber 2 , bn mount, 6374 motor, and caguamas.
yeah pretty much the same. I presume you’re using the right size belts so you don’t have to keep your screws pointing down like me?
Dont have a belt yet, I am still waiting on my wheel pulley and I still need to figure out my motor placement.
gotcha. Pulleys are gonna be a bitch for you since those axles are short asf. I found a good setup to be BN in the back and caliber 2 in the front.
cheap and very usable
So one truck will be longer than the other?
bn184s are almost the same width as standard caliber, the axles just stick out a bit more
When you know what belt size you need, let us know. I have a few sets in sizes I don’t actually need I could throw your way.
Thank you
So @Savage1 is practically giving me a 36t precision pulley. So I will probably just have to cut my trucks a little to make it fit. It will hopefully work for thr time being, and when I finally have time off from college and start work I will probably buy a new hanger.
I hope you’re light, otherwise you’ll have some bendi bois
Whats considered light?
<150lb.
I guess I am going to have some bendi bois
It is seriously good for mental health if you immediately write off every single part on your first build as sacrificial. In all likelihood, some shit gon bend or break. My first build, I put it together, I said “if it does, it dies, and I can build more.” And rode it til my motors broke. Still using most everything else that was on it.
