Thanks, but since I have never had any contact with chain drives, I dont feel comfortable making a build with them… Anyways I’ll do some research on the matter.
me neither and i haven’t given it any thoughts
Here is a good place to start some reading if you want to
I don’t have unlimited balls for something like that
The idea lives on, some decisions have been made, and I am more than happy how this develops.
I’ve made up my mind and will definitely go with 4WD. Why? Well, it’s fun and I have never done it before, that alone is enough to try it out…
On to the list
Deck - @Haeroboards - Haero Bro
Trucks - @ApexBoards - I hope those will be released in near future, if not then Matrix
VESC - @Trampa - 2x HD60
GearDrive - @moon - 2 Sets, lowest possible gearing.
Bindings - @MBS - F5
Wheels - @MBS or @Trampa - 9"
Enclosure - @3DServisas or @ApexBoards - so far 3D Servisas looks better fit since its made just for HD60 VESC, Downside is its 900g each, and thats 1.8kg just for enclosures.
In the next days I need to decide on motors, 6374 or larger. Any thoughts?
What bothers me the most is a battery enclosure, I have yet to start dealing with it, since it’s 4wd I was considering 12s8p - 12s10p of Molicell P42s, I am not a fan of how peli cases look, but on the other hand Trampa monster box fits 12s7p of 21700 and cost around 500 pounds.
Since I am really into aesthetics even knowing this thing will get dirty and scratched all over the place, placing a power leads to the VESCs on top of deck / over the bindings is not an option for me, I will be definitely routing the Bro deck to bring power to the enclosures, that said what do you guys consider to be a minimum lead thickness for this purpose?
And the remote… Don’t want to start thinking about it yet
Thank you to all who have helped this far in any way.
Yeap, thats it
I’d go 6384. that’s a good size and still not too heavy.
I‘m not sure how close it is for a release, but @ApexBoards might come up with a solution for the Bro deck to route power leads without cutting channels in the deck.
I would look into the Samsung 48g cells.
4 x 637x motors are overpowering the board already. There is only so much grip you can get down with small tires.
Cables:
TRAMPA WINGS
What is a reasonable Wh/km for a 4wd build range calculation?
50-ish?
Summoning @Battery_Mooch for a word of wisdom on those cells
He’s already done these cells
He’s selected 10A as the recommended rating and you’d need a high P-depth for those cells to make sense.
I don’t think those cells look super impressive, but of course that would depend upon what price you found them at, and how many of them you plan to put into the battery.
Yes, I think for a 7p it’s not quite enough. But 10p should be fine.
I would really like to go with trapma monster box, just trying to figure out the range I could expect with 12s7p p42 molicells
I would guess 35+Wh/km you can save set as consumption, depending on the terrain for sure.
That’s something in the 30-40km range with that pack.
Could also do your own enclosure save some money and gain some experience
I could, the thing is that I’ve done all my previous batteries by myself. And I am a bit tired of spot welding
getting a pack done by someone else and shipped to Serbia is a logistical nightmare. That’s why the no spot weld system from trampa is so tempting for this occasion…
@Trampa what would be solution for connecting 2 vesc hd60 to a wand remote considering the position of the vesc would be at the opposite tails of the deck.
I am trying to avoid running all 6 phase + sensor wires per side from the monster box to the motors.
I could eliminate sensor wires going HFI but would prefer running just 2 instead of 6
I have seen people having issues to fit the p42 cells into the trampa holders. Seems the cells are slightly wider than the average 21700 cell.
Or it’s a tolerance issues with the cell holders.
I would double check that, before you investigate a lot of money into that system and the cells.
IMO the Samsung 48G is the worst performing of the ultra-high capacity 21700’s. Yea, they have an estimated 10A rating but I wouldn’t use them above 5A or so to help reduce the horrendous voltage sag.
You are much, much better off with Molicel M50A, Samsung 50G, 50E2, or 50E3. Forget the 50E, it’s about as bad as the 48G.
You want to stay below about 7A for even the best of these though (pulsed or continuous). Their internal resistance results in a lot more voltage sag vs good power cells so you can’t run them hard and expect decent running time.
Just curious…what does Trampa like with these cells versus the other ultra-high capacity 21700’s?
Trampa have realised their 21700 pack doesn’t fit the very popular P42a. Frank will tell you he has done extensive testing of his designs when in fact what that means is he asked one of the lads to back flip the board with the PCB’s in and signed it off.
Now instead of Frank admiting this he will reccomend the only other cells currently available based on some science that Frank has convinced himself is right so that he can actually post this crap with conviction. Its a pattern we have seen over and over again unfortunately.
I’ve got to hand it to Frank, the spotweldless battery is a great idea and I hope it holds up well, but just be honest dude - It doesn’t fit the P42a, no biggy, you will make a new intermediate plate to accommodate them, but in the mean time you shouldn’t be reccomending poor cells to push units.
