5 posts were merged into an existing topic: Derail Jail 2022
I am sure that there is a place in the interwebbbs where conversations getting personal are more appreciated, but I have a feeling that this is not the place. Take it easy, this is an exchange of opinions on technical questions, and for no reason it should ever become personal.
Back to the topic: I am considering just having Meepo send me the ESC that they so desperately want to send to me (instead of the new battery, which it seems that most on here agree will be the point of failure). And then, when the thing arrives, inform them that actually the ESC does not solve the problem. Kinda strange for them to not come to the same conclusion after watching all the video material I supplied them with. What would you guys do?
If youâre cinvinced your battery is tthe problem, maybe you should send it to one of the trusted battery builders in europe, for repairâŚ?
Find some here
Ok then Iâm def out of this thread
Good luck @ridiculed
Sorry for the brief derailment ![]()
Itâs simply not how cells behave in those situations, or how hard braking ends up affecting the voltage of the battery.
To begin with, as soon as you remove the charge, the voltage settles lower than the charge voltage. How low depends on different factors, but rarely is a board literally âfullâ when you take it off the charger and go use it. Part of the buffer exists there.
Also, the moment you start riding, youâre drawing current. Starting from a stop takes a decently large current draw, followed by more moderate draws of current as the motors are driven to their desired speed and held there. So right away youâre drawing several amps for constant amounts of time.
When you brake on a board, the entire braking event isnât usually handled by regenerative braking unless youâre lightly riding the top end of the brakes down a long hill.
In the vast majority of braking events, the regenerating gives way to the ESC using more current to drive the motor in the opposite direction for higher strength brakes.
You can see this when you log data. Hereâs a screenshot during a test ride. And most braking events look like this, electrically.
Youâll notice that not only does the initial regen not raise the voltage very high at all, but as the speed decreases further, the voltage drops again as current is drawn to clamp down on the tail end of the brake.
I donât know who told you about waiting longer distances before using your brakes, but you have been misinformed.
As for the case of this Hurricane, an above opinion sounds correct to me.
The first failure is likely related to the cells, and the second is related to the BMS.
If it were me, or really if @ridiculed has access to a tech with this expertise, Iâd swap the BMS into the 2nd battery and test that, after I confirmed the ESC to be working normally with a known functioning test battery.
I realize this is probably not feasible, but it seems the ESC is indeed fine, and I imagine the prospect of having 2 junked entire battery assemblies is less than ideal.
Thank you for this.
Lots of information and detail here I have to work through.
Dont know from where i have this "wrongâ information about draining rhe battery first. For me it worked out well on these kind of chinese boards to ride a few km first before hitting the brakes hard, f0r a friend of mine who hit the brakes after going up a small hill first and then braked not. Many times.
I observed that with vesc you re âjustâ losing brakes, cheap esc destroyed the batteries ( that was what im thinking lol ) Many vids on youtube when dudes riding their chinese boards for a few km the first time their boards gave up. I always thought it was bc the battery was fully charged and they hit the brakes just to early. So, i always go a few km before using my brakes, but im riding vesc and no cheap esc anymore.
Works out for me without any issues si i stay that route ![]()
Beautiful breakdown, thanks @TheBoardGarage . Much appreciating the spreading of knowledge here, gotta say. Yes, the BMS change will be the way to go with @Simeon , hopefully that will do the job. Obviously, I would still like Meepo to âtake responsibilityâ while on warranty and send me a new battery, regardless of what I will do with the two âbrokenâ ones. Thanks again for commenting and âcleaningâ and so on ![]()
@TheBoardGarage is spot on with his explanation and Iâm glad you said it first so I didnât need to try and explain it. That much is also true even on Chinese boards with the only exception being if you go down a very steep hill very shortly after riding and you are on the brakes the entire time youâre on the hill. Even when I lived on a mountain I never reached the point of that being an issue though because the regeneration is not very energy efficient and as he said using the brakes takes energy too.
As for the issue with the battery, I had something similar happen. First battery died from being used too much and likely died naturally. It could still run while plugged up since the BMS was functioning. I was still under warranty and was sent a replacement battery. That battery then failed prematurely due to a BMS failure which is easily shown if you board wonât turn on when plugged up.
From what I could tell the BMS failure didnât kill all the cells although two P groups did seem to be damaged. The rest of the cells worked fine though and were able to be used in a different battery until I accidentally killed the BMS on that battery. (It wasnât marked and ended up not being designed to handle the current I was putting through it)
Iâd at least do some basic tests on the cells before using them with a new BMS just to be safe. Testing each groupâs voltage should be the bare minimum and then if you are able to test each group under a load to determine the batteryâs internal resistance. This page here gives you the steps to do that, and this article better explains why it matters. Personally, I compared the battery groups to each other to see which ones might be bad since I didnât have the values from before the first BMS failed on me. There are better methods to check cell health but the internal resistance can be checked with very basic equipment
