Hi there, not sure if this belongs here, school me if not.
So, my second (!) replacement battery of the Hurricane died on my while riding. I was riding for roughly one km with a fully charged battery, when, after pretty strong breaking and accelerating, the board did not respond anymore, the remote showed empty battery, and then showed the disconnect symbol. Board would not turn on via push start or start button after that. Moreover, I would not be able to get the board to start up even with the charger connected (my first broken battery still was able to do that).
I have attached a video of this (dropbox link), using both batteries to show (to Meepo) that the ESC and charger plate should be working fine (that’s my conclusion at least), and that therefore it MUST be a battery problem.
In case someone knowledgeable has a look at the vid: is my conclusion correct? Because Meepo first wanted to send me a new charger plate, and after seeing that video, they want to send a new ESC. I don’t think that’s the problem though, do you?
Battery is at 41.7V, which does not seem right. Remote shows all 4 bars on battery when the charger is connected. Charger shows a red light, indicating that it is charging, but you don’t see the charging process on the remote.
Not sure if i understand you right, but the first battery died while riding for 3 or 4 kms after a full charge. the voltage (41.7) does not seems right therefore, indicating a dead cell (right?). The first battery can be connected to the charger, board works fine. the second one can’t be started at all.
Hope I understood your second question correctly. Meepo really does not seem to like the idea of sending out a second replacement battery.
Some board BMS units do this so you don’t try braking with a full battery. (Regen from braking can only go back into the battery when slightly discharged.)
I can’t really blame them, as I don’t think your batteries are the problem here.
Can you take clear pictures of the battery connector wire (yellow) coming from your ESC?
Here is your mistake.
You are not allowed to break with a fully charged battery bc it will destroy the battery. When u have really bad luck the esc is damaged as well.
So…it kinda feels like the remote is setup for 10s, thus showing full bars but the battery being a 12s system shuts off because of the low voltage cutoff
