I’ll say this, any updates you make to pledge levels (like adding more) or rewards (like adding tyres for $1) should be communicated on KS via Updates.
It provides clarity and reinforces confidence to your backers.
Also, stale projects on KS rarely attract the backing they need.
we’re on schedule to get there (we’re getting there no matter what really)
I have like 150 12mm axle hangers around my house but we go for better, bigger, more fins and waffles, better thermal contact and most importantly a precision straight axle. should have the prototypes done in time before the end of the kickstarter to assure its good and then we go that way! not really a risk as the motor stays pretty much the same
other changes are huge inner bearing, sealed motor, motor wires routed in the hanger, much better thermal contact to the motor
ill get this prototype done before the kickstarter is even over. the motors will stay almost the same, just sealed and with a bigger bearing. I have these many other hangers as back up just incase
the 91mm tire is the plan and wont be far off since the expensive part of the molds will be done already but putting giant wheels or even off road wheels on a direct drive or hubs… it becomes inefficient and at worst Ive seen it can get so hot and effect the wire resistance and inductance so much as to lose synch with the esc. its essentially doing a reverse gearing. if you don’t plan to push things hard or do mountains maybe.
My speed board (or stupid board a.k.a mr beans if you want to call it)
Has 90mm wheels on it and can do 84km/h which scares me shitless when i hit the slightest little rock on thw highway. (I take the board out only at night in full motorcycle gear and go on the highway beside my house. It becomes dead around 9pm so i have 3 lanes of goodness for about 4km all for me)
Trying to push it to 100km/h (60mph) but its getting hard and its freaking scary has hell at those speeds.
You gotta stay in the zone when you it a crack, minor rock or anything that gives a little hit.
If you stiffen up its done, your out.
I still shake when i get off even though ive done it numerous times.
I belive it’s @MoeStooge himself that holds the unofficial speed record at something like 70 mph, unless @Lucifer beat it, which would not surprise me…
I know @Lucifer hits mid 50’s in up hill races like it’s nothing.
Dudes do this! These are the most durable drives out. At most u have to replace bearings. Best polyurethane. Smallest airgap. All steel parts not extruded and bolted with little screws.
Look at the reviews of the other stuff vs these and customer service. We need u to make it to the goal!
