I forsee my build for it might be awhile, we’ll see. Maybe i can hook it up to a temporary battery and ESC
Man I want a set of these so badly.
Linny, I don’t understand how your all your work is so goddamn clean. Well done
Thanks! I just like to make things look good.
I ended up filing and sanding the pivot cut so its 2mm shorter and was able to sit on the BN baseplate properly.
Heres a build i have in mind for a good while now waiting for them the past few years. A low rider!
The deck is a Kush Omen for those who are curious. I believe a discontinued deck
Pity your mum didn’t have the same skill set.
The mfg is Omen, the name of the deck is Kush. Omen made same really nice decks. Not sure if they’re still in business.
Nice
The back is wider than the front? ![]()
Wheel to wheel, like 10mm only, so not too far off. The front hangar is a normal paris clone 184mm btw.
I had the Same problem with my mellow hangers and BN baseplates. I ended up getting a 17,5mm drillbit and deepened the pivot cup hole just a tad.
Sits perfectly now
The perfect aluminum surface finish for priming and painting ![]()
Nice to see I’m not the only insane person on here to take the time to properly sand and buff aluminum parts to paint them. Those grooves must have been a pain in the ass though
I’m surprised that to see you put it on something so soon though. I always wait a week after painting before messing with my parts to avoid dents in the paint. Although I’ve been using enamel paint so it does take a bit longer to cure
it’s painted ? I somehow assumed it was anodised
Not sure if you need to prep the surface as well for anodising as you do for a good paint coat, but also he said it himself earlier in the thread:
SIR, porn is not allowed on this forum. please refrain urself from making us horny
I post what i want
From what I understand it’s actually more important when anodizing
Me too linners, prepare your body.
What the heck is that or is it ur own trick?
