Let me know if I can help, I’m riding my hummies whenever its not raining or snowing
Btw, do you have a exact model number of the fancy japanese bearings?
The new bearings or the old in what u have ? 6808 and 6804 is what u have. If send to u but ur far and it’s cold there I think
Wheels are changing from ~83mm to 62mm?
Jop, I know
but if nobody else will test them I’m ready
I meant the fancy single japanese that you send me. Tried to find another one but just using the numbers on the bearing didn’t help much
6808 and 6804 are the bearing numbers in what u have
The regular wheels I’d be getting made are 84x86 but the material they would be made of is the same as these 62mm I have. 78 duro and AA rebound. Just have to make sure they don’t fall apart so if u want to run these on a powered board and put a lot of miles in I can send them.
what city is your manufacture in? Shenzhen?
I forget right now why? U mean for motor parts r wheels r magnets? Sure something from there
Probably bc a lot of the country has been told to stay home until the 10th now.
Not like another week is too much of your timeline.
and based on how things shake out over the next week might extend it even more :o
(Not saying delays is your fault at all, just saying in general)
That Idea board with the brackets looks absolute tits.
@anyone that has these already, how are the hub sleeves holding up? Are they showing any free play from the motor?
Any pictures of the hubs showing that the sleeves are staying on the motors nice and tight?
Nobody has these as still in dev/manu stage.
You can check mine whenever they arrive. Or have them to test or whatever. You know I don’t care eh
Most likely it will take me some time to throw them in a build anyways
Well I don’t actually mean these ones but the ones that were sold before already. These new ones should actually be the same as those.
I’ve been running these motors for over 18 months now (the V3) . They are rock solid. The way they mesh in with the motor means they will never have any play.
Have you talked to @hummieee about trying the tires I made?
Hi, If somebody want to buy my spot on the line, let me know…
someone please take brads tires. @RipTideSports. They sit here.
Regardless today is the day I’m paying aend to do the new molds. the tires will all be the same 78duro as before.
@FredXanadu. !! Will push n get them to u this spring for sure
Are you sticking anything in the post to the UK?
A deck tonight. But U.K. is big! I can send the tires to u dm me and forget ur address.
Is it ok if we call them sleeves?
