that’s all that matters
u saying the force on the axle doesn’t matter?
im saying what youre saying isn’t right. regardless of what drive system it is, whatever force is at the road the same force is applied to that hanger. its that simple. forget the math. aluminum hangers where motor mounts attach aren’t ripping off the aluminum these days.
well if a stator is mounted by 4 bolts at the edge of the motor (as in a gear drive) versus a single bolt in the middle (some hub motor designs), then it is a different amount of leverage and force on the motor mounts, even if the motor produces the same torque. much more leverage and force is applied to the motor mounts in the latter scenario.
if anyone disagrees, prove it, just remove 3 out of 4 of your motor mounting bolts, and then put the remaining one close to the center of the stator, and secure it with glue and see what happens…
every motor has all the torque going through a motor shaft. a single shaft in the center have you seen the grub screws or keyways on high torque outrunner motors? they’re tiny. if you find another pic of an axle that broke that’s relevant and has happened not 3 years ago…then we’d have a point. youre talking about a non-existent thing. no one is running torque through 8mm axles that have a large load on them, way larger than 50lbs when you hit a rock at 30mph, …theyre running through like 5mm motor shafts or something.
then if its true motors don’t need mounting bolts, and there aren’t reactions for every action as well.
also because of the low kv (75kv) you use for your motors, they generate much more torque per amp than a 190kv motor, but spin slower which is appropiate for direct drive.
you were saying motor mounts don’t experience the same force on the hanger as direct drive that’s what I disagreed with. a thin shaft will have more stress than a big shaft.
the torque is the same in newton meters, but since the radius is different at the wheel edge and at the axle, the force is different. you appear to be confusing force with torque.
Happy afternoon everyone
If you remember just one thing from my reply, let it be this:
Loads by themselves have no meaning, the resulting stresses from loads have.
Elevated loads don’t automatically translate to larger stresses or structure failure, to make conclusions first calculate the stresses.
For 12mm axle, the stresses resulting from this moment will be ~45MPa, which is less than 10% of yield stress of any nice axle steel (or even Titanium)
Exactly, this isn’t even go entirely to the hanger/axle.
To make it closer, you can degrease your bearings and load them with sand and shitloads of red loctite, then test your torque by all means.
I don’t really sure what was the purpose of this thread to begin with, but any serious consideration of this topic have to include stresses and not just loads.
PS
I asked the OP nicely to stop this “elevated load” apocalypse of hub motors in another thread, but I guess he didn’t listen.
PPS
I can argue that standard motors/mounts apply larger loads on the hanger than hubs. The hangers see additional bending moment.
PPPS
I want to start a thread discussing loads and fatigue loads on hangers to demistify the issue and to supply some kind of design criteria for new hangers/motors/whatever. (But this thread was out earlier)
Happy Sunday,
Dani
I wish you would simply post the information here since we are already having the conversation. In your opinion, what minimum design features are necessary to prevent all future wheel separations with direct drive?
First get your definition right as far as hub motor and direct drive lol. They are designed and setup differently.
@professor_shartsis please use some annotated figures to explain your case, otherwise whatever you write on this forum will generally be ignored.
I didn’t go into the details discussed above, but if the stator is directly mounted on the axle, then axial stresses beyond what the material is able to handle will lead to failure. And like @dani said, the torque doesn’t matter but the stress. If you use a larger dia axle, the stresses go down.
In case of direct drive( I am talking about eLofty) the stator applies torque on the 14 mm square shaft at the very back using a square hole.
Irrelevant
I would think an acceleration force, in the direction of movement.
他妈的你在说什么
I’m just disappointed there were no animated graphs.
That’s what I thought reading when I was through this. And in the case the acceleration isn’t moving the board forward because of say a wall I’d assume the wheels would loose traction and spin before the force would be great enough to bend or break the axel. Of course I have no idea about any of the math on this and am no expert on physics but that’s just what made sense to me.
