0 and 0.
Ramping 3s and 3s
Damn. That should be perfect. Maybe you will have to try the calibration. Have you tried that yet?
Just tried that and still seems like reverse/braking is extreme.
I assumed this is just how they are since 4 of mine are like this.
its as if when I throttle up to let’s say 1/4 its smooth and starts to move.
Then 2/4 throttle up is mid power as is should etc etc.
The reverse is more like 1/4 throttle down is a small tug and 2/4 is a tug to reverse.
Basically I have just gotten used to it, but the forward is not the same as reverse even if setup the same values. It’s very odd.
No
I tried again last night while installing a new battery. In the calibration screen the ppm signal goes instantly from 0 to -100 but normally from 0 to 100. If I hold down “R” the problem persists but it goes smoothly from -100 to 0 and then instantly from 0 to 100. I think the remote is either mis-calibrated (I recalibrated a while ago but maybe I did it wrong?) or the potentiometer is busted. I’ve been meaning to take @JJHoyt’s offer of a facetime, just never got around to it.
that’s why i flipped the direction of my puck…the input for each wheel direction isn’t created equal. I’ve email jeff about it and many Lacroix owners also experienced the same issue.
Yeah but your puck can produce values between -100 and 0. Mine cannot, just skips all those values completely. On the same unity the vx1(ppm mode) works perfectly. I really do think I got a defective unit is all. It happens, no hate on hoyt.
@JJHoyt give this man new guts for the puck!
@GeraldSwerdfegger will respond and, if necessary, get on FaceTime with you to resolve.
Yes this sounds like a broken/faulty puck to me. Shoot us an email at hoytskate@hoytskate.com and we’ll get it figured out. Or just PM me.
I sent you an email, thanks!
Not sure if I understood this correctly but the PPM values of the puck are not symmetric. max is 2ms, min is 1.2ms and neutral is 1.5ms. If you are setting your PPM values at max 2ms, neutral 1.5, min 1; I could see how you would get this problem.
I let the app configure it.
An try and set all values like curve and ramping to same or 0.
IE 1 to 1 I believe.
UPDATE
A solder joint on the potentiometer was broken. And then right before sending it out to Hoyt I plugged the receiver in backwards (like an idiot).
Despite my stupidity, they fixed the issue and are sending it back today. Hoyt support really is unrivaled. Can’t wait to be using this again.
nice you gotta print a bruce homie - its the truth (also I want those finger loops for mine, so hoping you can print those too
UPDATE 2
USPS lost the package about 2 weeks ago
Update 3:
I completely forgot about this but I need to make sure that anyone reading this knows that @JJHoyt sent me a new remote and reciever when mine was lost in the mail. He even had it engraved again. What a bro.
If you have a puck and haven’t reflowed your pot solder joints yet - definitely do it asap.
Mine tried to kill me yesterday with random brake/reverse signals at full speed
I think getting a bunch of likes on this post recently, just wanted to say that when I showed up to carve PDX with another remote having the same issues, Pete from Hoyt soldered up a fix on the spot.
New pucks have a couple of changes that help reduce the chance of this happening.
Anecdotal warning: Ive seen plenty of failed puck pots locally. None of them were epoxied.
The one that was epoxied(mine) has been smashed and crashed heeps, to the point of fishing everything out of the adjacent waist tall grass after stack. It’s missing partial resistors and hasn’t skipped a beat otherr than no charge indicator lights(blank but goes green when full).
The local failures have been a healthy mix of pot leg failures and internal pot failures so while epoxy helps heaps, the pot can still go bad.
F
What is going on in this thread?
And why did my puck receipt show metroboard instead of hoyt?
@xsynatic please move everything from post 109 and onward (including this post), to the thread linked below. All the flagged posts are off topic, but it is a valuable conversation about battle hardening and potentiometers.
