I set up my Hoyt puck on my unity and now ANY amount of “brakes” (happens whith reverse on and off), the ppm signal shoots from 0 to -100 instantly. I confirmed this in the Unity app. When I hold the “R” the problem reverses. It goes from 0 to +100 instantly.
The reversed behavior makes me think something is wrong with the remote itself. What is the screen name of the Hoyt guy on here?? Please @ him.
A solder joint on the potentiometer was broken. And then right before sending it out to Hoyt I plugged the receiver in backwards (like an idiot).
Despite my stupidity, they fixed the issue and are sending it back today. Hoyt support really is unrivaled. Can’t wait to be using this again.
Update #2
They ended up hiring me and I worked for them as a production engineer for a year and a half. The puck still breaks when you break it. I hear they’re working on it.
I cannot get the first step to work. Should I do while the remote is off? While it’s connected to the board? Hold or press?
Tried to calibrate and completely fucked the controller bc now it goes full throttle forward and back with any slight (insanely small movement) of the thumb wheel. How do more people not get hurt with this?
As this is the very first reported issue with what is universally regarded as one of the best remote options available then the title is indeed very un fair.
I suggest you change it please to something less dramatic because the issue could be any number of things. Change it to something less sensational or one of us will.
The remote was working perfectly on my other board. All I did was move the receiver and setup through focbox UI Android app. Just like I did on my other board.
