Took the officially done skateboard for a late night (or early morning) ride.
Question first:
How much can I tighten the bushings? Can I tighten them too much? I want to have better handling at higher speeds, but I’m a little worried I’ve already tightened them quite a bit.
Anyway, the ride went well. Bending at the knees is important I learned LOL. I have the motor speed limited in software and it’s still super fast, plenty of torque. Which it was two wheel drive so it was more balanced, but would definitely want a weaker motor if I was gonna have two. This motor by itself is more than overkill. 5kW is powerful!
I also had my first official fall. There was a speed bump, I thought I could take it, I went slow. Suddenly, bam, I’m jolted and fall. I’ll eventually get use to it and do it alright, that’s not the issue. The issue was the foot straps.
It felt like suddenly having the rug pulled from under me. You’re strapped in, which makes even low speed falls a lot more dangerous that they should be. I fell forward so there no real way to fall properly while anchored to the board.
However, I don’t want to forgo footstraps, they provide great handling. I’ll definitely have to look into those half securing foot straps - will probably print my own.
3D printing has proven itself. I created a test hook as shown in CNC Kitchen on youtube. With the right parameters, I created a hook in regular PLA that I literally hung from and it did not break. I even jumped into it before hanging on and it wouldn’t break. Strong stuff - just need as many lines as possible in the direction of the load. Now I’m using PLA+, which I’m sure I’ll be able to use to create amazing functional parts.
Speaking of 3D printing. I created a custom mount for the ESC. I was worried the ESC might get a bit too hot for the PLA+, so I annealed it too. The research shows that it can more than double its heat resistance! 3D printing is just one of the best things I’ve ever done. It’s making my life so much easier.
I was worried that my upgrades and messing around with settings would degrade the printing quality, but I’ve got a good handle on things and the print quality is as amazing as ever.
