i just find another problem with ackmaniac , my remote failsafe doesnt work everytime and its a big problem for me because when i cut the remote the vesc is at full trottle!!
What remote?
ppm gt3b
I donāt know about that remote but maybe try this way to set failsafe
It might work, who knows
the thing i donāt understand my failsafe work well on vesc tool
problem solve everything work with my gt3b
Has anyone gotten ackmaniac to work with Unity? Iāve seen people mention that it works with the old school single focboxes, but I havenāt heard of it running on unity.
@mmaner is probably the homeboy you want here.
I doubt that is possible without a complete rebuild of the code. I wish it did though.
I had to repair a VESC 4.12 (replaced a couple of FETs and the DRV8302). But I then managed to flash the wrong firmware (firmware for the CFOC2). Now Iām unable to flash the correct firmware. If I simply open the tool, it shows me a list of hardware options and the associated firmware. But once I connect with my VESC 4.12, it thinks itās a "Cheap FOCer 2), and the hardware and firmware options disappear.
Iām guessing I could still flash the correct firmware if I could find the .bin file and load it as a custom file. Can anyone tell me where I would find that file for the VESC 4.12 - or give me another workaround?
I also have an ST-Link, and another VESC 4.12 with the correct firmware on it. Can I somehow grab that firmware from the other VESC?
Thanks!
The good news: Turns out I was able to find and flash FW 5.10 for HW 4.12.
The bad news: It looks like I managed to burn out my new DRV8302 - hopefully from having attempted motor detection with the wrong firmware. New DRV8302ās are on the way.
I donāt care if it costs me $1000 and 1000 hrs to fix this $80 board. I intend to defeat it!
l found the same problem , the best is 3.103 with ackmaniac tool
you can try to write the firmware also is included with the app
i am back here for another problem , why l can,t get the watt mode function enable with android app ? because anything else work very well.
in windows my tool the watt is set to max 15000,0 W
usually I leave it at max and only touch the amps, what is your goal?
watt max allow to have the same power all the way so you donāt feel the voltage dropping but l want to this feature to work on my phone so now l will try to lower the value on my pc app
In the Ackmaniac android app, are the motor/battery current readout values a combination of both sides? Or is it the value from the side the bluetooth module is plugged into? i.e. if the app is reading drawing 20 battery amps, am I really pulling 40? (20 both sides) or 10 each side?
Also I have a 12s4p 30q battery. I think my battery settings are off. The app is reporting 13.4 wh/mile. Most of the calculators Iāve seen estimate about 12-13 wh/km so I doubt my setup is that efficient. or again is that number per side? so itās really like 26 wh/mile?
i know its a old tread like me
but i just finish rebuild of my board today and I donāt remember if the bluetooth module (UART) goes on the slave or master for dual setup thanks
i have a brand new boardnamics drive with brand new 190kv 6384 motors and i got āerror hall sensor 255ā and its the same result with both motors
just switch to the official vesctool already ![]()
i canāt i already try fews year ago , its 4.10 hardware and i have lot of problem , bootloader problem etcā¦
