I the ESC-Tool, check the com port selection.
If your not getting the sound from windows, you are likely note getting a connection.
Yeah in the tool itâs on com1
I guess I rode them so hard I broke all the ports?
yep it was just the loose ass USB port, wiggling got it to connect
Anyone running ack firmware 3.103 on VESC-X, older focbox? How they holding up?
I donât know if the VESC-X can take it? Donât want to blow it up just yetâŚ
Use 3.102, I put it in my evo for a couple months running way higher amps then itâs rated for and itâs ay ok
How much amps you running?
Which mode? Hybrid? Foc? Bldc?
I am, running 60a battery in hybrid mode with no issues.
It was Hybrid 80a batt (I know lol) and 90 motor. When I went two wheel drive I put v1.6âs in though since Mikes package had just come in.
Donât die
Please tell me you raced Mario against the rc car
aint no thing.
if someone can tell me why my 115200 bluetooth module doesnt work with the android app ?
I also try with 9600 but still no connection , I also try to connect on master and slave side âŚ
the module i use is from flipsky and need to be set to 115200 and work perfectly on the new vesc tool app ,
The FlipSky module is an NRF not a Bluetooth module.
ok thanks explain me why how i can use it on the my phone with vesc tool but not ackmaniac
I downgraded to ackmaniac because i canât set up my dual motor in bldc mode properly
nevermind I will buy a hm10
Ack only use an HM-10 module, not NRF. It is just not compatible with the communications requirements for the application.
If youâre using BLDC mode, Ackmaniac is not a downgrade.
IMHO itâs if youâre using HFI+FOC that is a big reason to not use Ackmaniac
i canât use foc mode i am on 4.12
Ackmaniac is totally fine then
Ack FOC works flawless for 3 boards Iâve made
Focbox v1.3âs and 1.6âs in those boards all running FOC sensored.
Edit: Just saw you meant hfi
