Take each piece off and shake it, identify the rattle and fix it. Then reassemble. That’s what I do. Obviously use weatherstripping between the enclosure and deck and use foam inside the enclosure. Nothing should be moving in there
lots of foam and hot glue, thats what I do. if you want a build where nothing moves, you pretty much have to pot the electronics (everything i the enclosure) in silicon.
Rattle from enclosure or rattle from trucks or rattle from wheels?
I’m a noob at packing a solid enclosure .
But trucks and wheels are easy.
Alot of rattle ive seen is due to improper spacers between bearings in wheel ( and if bearings in pulleys) spacers between pulley bearings and wheel bearings.
Double side tape works wonders for more modular pieces such as bluetooth and remote receiver. Silicone and hot glue (THE BLACK ONE) for parts that are bit larger.
In my experience, using foam as a cushion did not help. Even with my VESC secured with foam, it would still vibrate around and eventually dug through the neoprene foam and start hitting the enclosure.
Not really a rattle but i’ve got a noise that comes from play in my motor shaft. Everytime i go over a bump i get a clink noise and it drives me nuts.
I can replicate the noise by hitting the motor pulley with my hand. I’ve tried adding extra washers to reduce the shaft play but no matter what its still too loose and makes the noise. Anyone else had this issue?
I’m at the point where I just want to replace the motors and forget about these noisy ass ones its that bad
I have a Tampa Street carver and I can’t work out why but the front trucks rattle like a bag of bolts. Checked the bushings, checked the bearings, checked the spacers. Still rattles. Always has. I’ve kind of accepted it now.
I have been dialling in my sons comp scooters for years now and rattles on the skatepark mean I am not doing my job. I have a ocd against rattly hardware.
Correct sized spacers for wheels and soft risers for trucks. Wax your bushings and pivot cups.
Enclosure should be viewed like a camera case. It doesn’t matter how well you fix any component, it will move under vibration and you want it to to a degree because you don’t want it to be solid and feel the total road vibration. You want it to be able to move in every direction but be cushioned in every direction to alleviate stress.
Vibration is the killer of all things esk8.
I can’t remember who said this but take your newly built board and bash it wheels first against a wall for 30 minutes…
