I’m gonna respectfully disagree LHB on a couple of points @BallisticBullocks but first, I wanna clarify that I don’t think anyone is trying to scare you off. If anything, the community collectively tries to impress upon people who wanna jump into battery work that there are very real risks. Battery fires are a risk to life, limb and the hobby. If ur aware of the risks going in, then you can take steps to mitigate those risks. Going in blindly w assumptions that something is gonna be easy is not the right approach imo.
I don’t think swapping out a bms in easy at all for a beginner. It’s not modular, and requires that the individual knows how to identify cells 1 through 12, has to be able read and understand a wiring diagram and must know some tenets of battery safety (e.g. insulating groups, routing balancing leads safely). Plus, soldering. I think @BallisticBullocks said his soldering was a bit weak.
This is very true, unfortunately. We typically recommend people to read the battery builders thread in its entirety but it’s a fucking beast and you’ll go cross-eyed. It took me months of reading and taking notes and shit and the thread was half the size at the time.
We really do need a better battery wiki on here. Maybe I’ll take some of that on in the off season…
@Lee_Wright has a great video series detailing all the steps of a battery build. Check it out:
How To Build An Electric Mountain Board - Making The Battery Part 1 - YouTube Part 1
How to Build An Electric Mountain Board - Making The Battery Part 2 - YouTube Part 2
Last, I’m happy to help you troubleshoot the battery once you’ve familiarized yourself w the battery basics thread. You can also bring it to the battery builders thread and have a bunch of experienced builders (more experienced than me) give their $0.02. Share lots of pics. Ask lots of questions. Listen to advice. If ur unsure if something is safe or not, assume it isn’t until u hear otherwise.
Cover your connections when they’re not being worked on
Once u read the battery basics thread, I’d start by clearing your work station of anything metal, taking off al the insulation on the battery, taking lots of pics from all different angles, covering those connections again w some painters tape, and then posting the pics in the batt builders thread. We can help u sort out the p-groups and then guide u on where to measure voltages from to see if you’ve got a dead group, if one of your groups has broken welds, or to diagnose a potential bms issue. Cheers
