Assembeling the batteries and wondering where do I attach the balance leads? Also my bms has 13 balance wires what do I do with the 13th?
Thank you all!
Check the diagram if available. Usually the first is for main negative and the rest for positive in specific order. The last one on main positive.
Holdup, send u stuff in a min
How do I bypass the discharge on this?
Ok cool and that bypasses the discharge function of this bms?
For discharge only
What @anon54720240 said ^^. I thought it was to battery positive on my first bms. Big blue arch. I had to rip the connectors off as they soldered themselves together. It was a scary experience. Smh. I felt very dumb that day.
Wait so where does the 13th balance lead connect to? The one on the very left
Still need help with this. Not 100% sure what to do with the last balance lead. It seems to me that it goes somewhere on the positive side but I am not sure
It should. If it’s a 12S with 13 balance leads the first one is usually a redundant ground connection. From there it’s just series 1-12 with the remaining 12 cables, starting at the first series and working your way up to battery positive terminal (connected to pin 13 on your BMS).
I think that @BigZwatt was referring to was the fact that most BMS use common positive and individual negative planes for B-, P-, C- etc, and he mistakenly plugged a positive mains into one of those (allegedly).
PS: Is there a reason you’re jumpering P- & C-? Something specific to your BMS? Not to say it’s wrong, just curious on the why
in short, yes. but kinda confusing since load- and charge- are shown as same connection.
assuming you got the balance leads right, see if this helps
So this bms has 13 leads the last one is shown to go to possitive, this is correct right?
correct, extreme ends goes to Batt+ and Batt-
