Isn’t that quite high if its a per side # for a 4p?
Ohhhhh is that a single whooooops my brain only thinks in doubles
@Taraskasyanyuk if that’s a Tb6 or a single of any kind split the batt values. In half so 45/-15
Faaaaaawk, I set it and bolted on the enclosure lmao. I’m guessing if I ride it with 90 it’ll fry something?
Not necesssirly as I don’t think you’ll pull that many amps but I would drop those values down:joy: safety first
The real question is why do you not have a metr ???
This would all be so easy peasy
I’m pretty sure anything but the unity app needs values to be set on a per side basis. @DerelictRobot has driven this in my thick skull a couple time.
Yes
Can you set those values with a metr on IOS?
Yes under the expert tab
