Help with VESC tool
Yes. Exactly that :rofl:
It @Chibatterysystems OG GANGSTER :sunglasses:
12s8p 43.2v 24 AH 1036.8 WH I :thinking: think
https://chibatterysystems.com/batterypacks/battery/12s2p-432v-8ah-345-wh-samsung-40t-e-board-pack-2cr8z
Yeah not sure about any wire sizing, but this is the battery! :joy: it does have one bend point in the middle.
To give you an idea, I did what this video told me step by step so that’s what I’m running :joy:
It feels good, just wondering if I could change it up.
Says the guy in the boot… :eyes::thinking:
Sometimes the trigger gets pulled to hard tho👀
I would
Consider that “lack” of control :man_facepalming:t3::man_facepalming:t3::penguin:
Edit: I kiddding… please don’t sabotage the pack :eyes:
I have to words for you penguin…ThReADed InSerTs!!
Shit I might need to actually change some values on my Unity later tonight after all this discussion. Or maybe install the 60D in my Evo :eyes:
Ahhhhhhhhhhhh faaaak… I deserve it :penguin::joy:
It will say a size on it if you inspect the insulation, it’ll say something like “10AWG” or “12AWG”. See if you can find that. Might be in square millimeters. (mm²)
10 awg silicone super high thread count wire.
You can probably set battery maximum at 45A for each ESC then
Even a little higher as long as battery Has a xt90 connector
I wish this thread was here like 24h before…
That’s not good. The DRV errors are really not good.
blown drv on my first ride on my first diy with low settings and a skinny rider
guess who the new schleprock is now @xsynatic
Reviving an old thread because I have new shit now and still don’t know anything about these damn settings. I need to get gewd.
I have a new pack, 12s9p 40T and the same 6380 190kv TB motors with TB6 ESCs. These are the default settings after running the wizard or whatever. What about this should I change or keep?
@CiscoV @Skyart @b264 @ahrav
Me personally would set motor max min to 100/-100. Batt max 95 batt min -35
:smirk::penguin:
You can probably go higher but with 2WD you might start to run into throttling issues but then again I’m no expert on this shit especially 2WD.
One day I’ll do 4wd :rofl:
