Hi
I have a dual 6380 170 k setup with a Unity.
When I quickly go to full throttle, the motors will cut out.
If I accelerate slowly it doesn’t.
Can anyone give some advice?
please also provide battery setup and also setting of unity
Battery 12s4p
What do you mean by unit settings?
I used Vesc tool
On a besoin de tout. Les paramètres du vesc, le type de batterie, le nombre de dents sur votre transmission… TOUT!
Ok merci
we still need those settings, doesn’t matter if u use the unity ui or vesc tool. do u have metr? some logs would be easier to help debug the problem
Vesc tool 2.06
Vesc firmware version 5.1 hardware: unity uuid : 37 o 2D 00 16 47 39 33 37 33 39 39
Moteur 6380 170kv torque
Roue 110mm torque
Transmission 16 / 36,
Batterie 12s4p
Remote flipsky vx1
quelles cellules?
(what cells?)
Je n’arrive pas à poster une photo’
mince, c’est parce que t’es nouveau au forum
(damn, that;s because you are new to the forum)
@longhairedboy i see you typing
@PixelatedPolyeurthan Just wanted to say thanks for the language assist and helping him get the answers he needs.
are you able to give a bump?
otherwise
i forgot, if you are new, can you post pics in PM’s or not? in that case i’ll just take it to PM
i put him on L2 so he can help himself a little better.
Мне очень нравится эта мультиязычная ветка форума
(I really appreciate this multi-language thread)
Greets from Russia
Merci pour ton aide mais je vois toujours pas comment poster une photo
if u r on pc, just drag the pix in the reply box, if u r on mobile, then on the bottom right corner of the reply, there should be an upload button for pix
