Hey everyone,
I had one 8.5’’ offroad Hoverboard lying around and decided to use these parts to build a budget e-Mountainboard.
I got all my parts ready, but I struggle with setting up the Hoverboard Mainboard. I just don’t really get how to connect the rc receiver. Becuase of it’s low price I ordered a Mini Remote and would like to connect the receiver directly to the Mainboard. It supports UART, PWM, PPM, and iBUS input (don’t know what the mini Remote uses).
Is it even possible or do I have to use an Arduino to connect the receiver?
It is a well known hack and there are a few more custom firmwares from other developers.
People build their own rc lawnmowers, e-wheelchairs, gokarts and so on with these firmwares.
It is also possible to set up higher speeds than the original hoverboards can reach.
With Arduino it is possible to connect any remote, but I would like to connect the receiver directly to the Mainboard.
@b264@iNoLikeFlexyDecks I was now able to connect the receiver to PB11, Ground from right Sideboard-Cables and 5V from right Hall Cable and bind the mini Remote.
Now I am facing some other problems, but these can be adjusted somewhere in the firmware I think:
The motors spinning full speed by pulling the trigger just a little (1/4 range of motion) and breaking is faulty.
As far as I know for all Hoverboards with Mainboard and two Sideboards (these are also the most common).
But for others there are also hacks linked on EmanuelFeru’s github.
First post at this forum.
i am trying to utilize the hoverboard mainboard for e-skateboard project
i installed the four pins and uploaded new firmware to allow throttle control succesfully (i think)
but i can’t make the throttle move the motor
i tried connecting from throttle to hall connector
black - black
red - red
the third wire i think it is blue i didn’t connect it to the brakes , is it a must ?
the hall connector from motor to the mainboard.
can someone help me and explain what wires need to be connected to where?
in some mainboard pictures the hall sensor is the left and right of the four connectors down
and in some pictures it is in the middle. so i am not sure where the hall sensor goes to.
