Hey Everyone I have a quick question. So I am fairly new to the whole Eskate world but I have some RC experience. However this will be my first time putting a BMS onto Lipos. I am using the tutorial from mutantbass LIPO Charge only Smart BMS wiring Guide However I am just a little lost on the actual charger part of it. I am using 4 3s 6200mah batteries. Any help/feedback is greatly appreciated. Thanks
you can get a HOTA dual channel crager, makd sure it’s the ACDC version or else you need a power supply
or an isdt 608AC
you can also get a parallel board to charge all batteries at the same time, but you have to make sure not to charge batteries of different capacities or s count
you must also check each pack before using the parallel board, don’t charge packs that are .1V apart per cell
so for 4S don’t charge the packs in parallel if the whole pack voltage is .4V different
