Stop skipping ankle day and this wouldn’t be a problem. Hypertrucks can ride just fine at speed even on blue/white bushings if you know what you’re doing with channels.
The fact that all you kankled baesk8 riders have trouble throwing around 50lb boards on a diet consisting entirely of Soylent & Vaping is unsurprising.
Aww. Miss you man. I’m not even gonna argue with you
Hope you’re doing well homie
For the record baesk8 is now All about unicycle, scooters and ebikes “onyx crap for the most part ”
Soon enough they’ll need to update the Name of the group to something else
Just gotta find those that actually skate… Or don’t… Haha
I mean, ya really can’t. I put my friend up North that never rode a skateboard growing up on hyper trucks. He was 35+ and comfortable on LoveDick at 55lbs on hyper trucks. Whoever you had ride just didn’t have any balance. Or doesn’t know what a skateboard even is. Haha!!!
I’m glad to hear it, I hasten to please you, I adapted my drives for trucks matrix 2, very soon, when I receive a sample of this trucks, I will take beautiful photos, while there are only simulated samples, to check all sizes
Low voltage, low ratio, low kv, all go the same way. If any of those values are fixed for whatever reason (say you’ve already got 190kv motors), then you can reduce or increase the other values to reduce or increase top speed/torque. Obv it’s not an even trade off, but 10S @ 100A/motor is ~4200W just like 12S @ 83A is ~4200W, but the top speed is lower on the 10S setup and you have more torque available.
The ESC does the conversion for you… Just because you have a 12s 30A battery doesn’t mean you can’t do more than 30 motor amps if your speed isn’t maxed out. So in your example, you will have the same torque per speed available in both scenarios, it’s just that the 12s one will have a higher top speed.
