Tell that to my pom gears the have over 6-7k on them and still look brand new. I use my boards for transportation all year round as I don’t own a car. You just need to know how to set backlash correctly and you can forget about them forever.
My motors will burn out prior to my pom gears. Which they have.
two slave gears actual don’t provide gear reduction, it just help increase gear contacts, power will divided into 2 slave gears, then two slave gear into one.
Forgot to mention, the gear ratio is fixed.
*The gears come in a pre set alignment.
*also, angular contact bearing has directions, the user might get it wrong, so it all will be pre-installed.
These are meant to be mounted outwards right?
I can see massive clearance problems when mounted inwards due to the increased height of the two slave gears.
