Those who need the 91mm channel width can use the original GF reinforced boards. Those who are ok with the slightly reduced width could use the new ones.
Just wondering what speeds everyone goes on this sick little deck?
I have some haggy trucks and oh they’re sweet!! huge thanks to @haggyboard.timo kinda want another set hahaha.
Im getting to around 30km/h mark and getting wobbles and was wondering if anybody has any suggestions?
Bushings are tight not too tight but reasonable I believe. I ride an evolve gtr had a gtx and can go top speed on em (40-42km give or take) with trucks fairly loose.
I honestly don’t wanna go top speed on this board which should hit some nice top speed (12s4p 30q / 6374 190kv / Gearing 36t/15t) but I’m lying I wanna hit it at least once hahaha.
Im also not even near full trigger :0
With this all being said only done one ride which was 25km. I may just need to ride some more
That’s nice Have you gone faster on other decks? It’s short(33") with zero flex at all and will get unstable if you reach it’s limits and your limits control-wise.
What are the angles at?
@RipTideSports sounds like you could save the day here
Yeah gone 40km/h on exway x1 pro which is the closest thing to being the shortest deck out of my collection (which isn’t short pretty long) besides the haya.
50 degree baseplate.
This is my first shortboard and by no means am I unhappy and I don’t claim to be the best at controlling but I handle my gtr pretty well imo.
Some griptape would probably help alot if I put some on xD
Sounds like you can massage a little more speed out, the Xway is 6" longer, not sure of the baseplate angles used, but a split angle setup may help wedge/dewedge. Brad would know where to ballpark this, also if anyone else is up and running they may have also discovered the stability gains.
Yeah definitely griptape! Do that as a matter of urgency, aluminium is too slippy to trust!
Try using split angles, the trucks are quite wide in comparison to the length of the board. Other more specific suggestions should be provided by an expert like @RipTideSports (Hi Brad)
Short WB decks can definitely benefit from a split setup to take some of the turn out of the rear. 50 is steep enough for the front so I would just de-wedge the rear. Let me now if this is something you want to pursue.
Yeah. A .75" sidewalk crack at 5mph.
Cool stuff. Weakest deck I’ve ever ridden .
. 13 miles total on board
Batch 2? Mine lasted quite a bit longer, but failed the exact same way.
Knowing so many from batch two failed this way, I’d have fiberglassed the whole thing before setting it up.
Looks like lack of glue to me.
Eyyy i was right! That was a glueing issue!
Yep, their customer service is amazing. I had purchased an older one from skyart, and messaged them as it was a version that was known to have some issues, and they immediately sent the newest version.i just had to pay the 40 bucks for dhl express.
Any Haya owners have issues with remote signal? What remotes are you guys using? I’m having cutouts with a VX1 and wondering what to do about it. Can’t reproduce it at home though. Should I just blame flipsky?
yes
I went through a couple VX1 remotes myself. Cut outs, then full on receiver failure.
