Just need to eat more
Or use some angle riser. 5-10 degree can change a lot in terms of turning radius.
I’m not keen on using plastic risers unless you know where I can get one that’s solid and covers the whole part of the Trampa/mbs truck?
etoxx has some
Sold out on the the +5 and +10
just drill the Haero out dude, take the hanger off and use the baseplate as a guide to drill the holes, thats what I did when I was riding trampa trucks on my bro
Thanks Lee, I thought the holes may be too close if I drilled, I’ll give it a go this weekend
5 or 5.5mm drill bit and make sure you use washers on top of the deck as the barrels will try to pull the bolt through the deck
Thanks bro, will let you know how it goes
Jep, if you do it carefully with a sharp drill that should be possible. Or just use the pink Trampa barrels. Not many people need it even more carvy
Hey!
I’m using one of your decks for my current build and quite frankly: i love it! I have the medium flex and it’s wide, it carves nice and has exactly the right flex for me (80kg).
I have to agree with everything @Lee_Wright said!
Couple mm longer, precut channels with some sort of lid for them, inserts for top box, available under mount enclosure, SLIGHTLY narrower nose and tail. I like a super wide stance so that might not be for everyone but that’s my wish list!
Actually it’s not mate . I don’t want to give anything away for Haero but prototyping continues. This was just a collaboration we did with some changes we wanted.
Exactly, the Apex deck is a collaborative design and is 1:1 despite the battery box inserts. Like @Lee_Wright said prototypeing is ongoing. As good things take their time and we don’t want to offer not 100% perfect designed products it’ll be more likely a Christmas present 2021 or even Easter present 2022
BUMP
Any word on a channeled deck? Still would be super interested in this, and I’m planning to run a super high-capacity board at some point 2024. Thinking bottom mount battery with an add-on top mount for extended range. 13S, 2HWh at a minimum, maybe up to 4…
It will be available within 2023
Any dates yet?
Within 2023
Bump…
It’s 2024…
