I don’t know exactly. I am pretty sure it is just a single stack.
And you know me bro… I don’t need to stinking ground clearance…
Yes you are.
Where are yall buying this deck at?
Well, enjoy gents
Edit : STEP for the CAO/DAO player, STL for a quick and easy finger skate ^^
Thanks for the upload Raiko
I think the HS11 curvature will flex down the HaeroBro horizontal deck into a canoe shape .
give it a shot
It will fit the footprint, but I don’t like the idea of trying to make it fit to the concave and curves of the Haero.
A bit of foam tape?
Sika fixes everything.
See? Not difficult at all.
i can’t tell if you’re being facetious or not.
I wouldn’t do it. I would much prefer to see what Alan can come up with for a purpose built Haero enclosure.
@glyphiks
There
@Haeroboards
Maybe @BigBen can help with a fitting enclosure He done some R&D allready
…or maybe 'ma boi Alan (@eBoosted) could
also come with a nice solution, as well.
Lo mismo here!
Even thou I already have everything setup inside that same enclosure and all I would have to do is install new insertS on the bro
I can’t see myself putting that kind of stress on the Enclosure. Besides sitting flat the enclosure will be bending backwards
Better if @eBoosted can make a flat version of it
I think he will. HaeroBro is becoming a must desirable deck.
Dejame botar energia. A estos hay que romperles las pelotas cada que se pueda.
