Matrix2 hanger is around 300mm I think.
That would give an additional 10mm on each side then depending on where the gear case will sit. Could work, but I guess there is still a bit a riser needed. Still only a guess.
Give it a try and we will know for sure
By the way, the 3DS hanger works with matrix base plate than?
The trucks are on the outer mounting positions. I used a @NoWind +5 degree wedge in the front and -5 degree in the back. I haven’t tested it for lean yet, because I need longer hardware.
I reckon if you wanted to use the inner mounting positions, and didn’t want to cut the deck, you’d need more than 1cm riser or maybe -10 or -15 degree in the back so the truck turns less.
Only guesses at the moment though, because I haven’t tested it yet.
If you have MBS or the newer bolt pattern trampa trucks they will fit. I know what you mean, they are not as wide as the full baseplate but they fit the bolt pattern
Already checked the back for clearance. This is me with my full weight (93kg) on one side with my heels complaining for the Vicious grip. Feet are completely off the ground here.
