Good Deals Thread
$34 for a set of 90mm wheels and bearings.
shipping is free.
Code for 10% off the meepo wheels
BF10
“uP nORtH HerE”
https://www.kaly.nyc/shop
Kaly is having a Black Friday sale, looks like some good deals on decks and enclosures.
Any esk8 Black Friday stuff popping up yet?
Did you check the black friday thread?
Yep. It was posted after I posted here :rofl:
https://a.aliexpress.com/_mOGTZV0
Cheap skateboard wall mount
Alternatively, pay the same (or pay 5% less if that coupon shows for everyone) amount and get two wall mounts that are known to be well made, hold up to abuse, and won’t take months to arrive.
The one you linked ends up being $10.99 for one when you count the shipping cost to the US
Disclaimer: it comes with generic drywall anchors and I would recommend using the highest rated dry wall anchors you can buy at your local hardware store if using it for Esk8s. But who doesn’t already have a box of those? if you don’t then you need them anyway
Those look like hot dog water but thanks!
I like the acrylic flat plate look to hold remotes and charge bricks. Tiny little steel arm covered in goofy foam noodles isn’t my favorite.
If you like that, you can be even cheaper and just go to a hardware store. They sell screw in garden tool hooks that look the same for like $2.
https://www.homedepot.com/p/Everbilt-Heavy-Duty-Vinyl-Coated-Screw-In-Tool-Hanger-50-lbs-24255/205020421?source=shoppingads&locale=en-US&&mtc=SHOPPING-BF-CDP-GGL-D25T-MULTI-NA-Multi-NA-SMART-NA-NA-NA-NA-NBR-NA-NA-NA-PortablePower_SmartShopping_HighOrganic&cm_mmc=SHOPPING-BF-CDP-GGL-D25T-MULTI-NA-Multi-NA-SMART-NA-NA-NA-NA-NBR-NA-NA-NA-PortablePower_SmartShopping_HighOrganic-71700000081625943-58700006942154417-92700062499001880&gclid=Cj0KCQiAkMGcBhCSARIsAIW6d0DzOYdN4fuHbElRE14B7QoroZ2Hmzm4VH1fFjB-OS61R2QmbtYXcLoaAlbQEALw_wcB&gclsrc=aw.ds
https://www.homedepot.com/p/Everbilt-1-4-in-x-3-1-2-in-Vinyl-Coated-Steel-Screw-In-Tool-Hook-15-lbs-01215/202305569
Nothing against you or your preference, but just wanted to make sure people knew it might not be the best deal for a wall mount. If it is the best deal for that flat look then my bad. I’m not exactly picky when it comes to stuff like that.
The problem with those ones made for tools is that they’re designed only to be used on solid wood aka a wall stud. They also look like they leave one huge hole in the wall vs only using 4 small holes that are then filled with drywall anchors. If you’re in an apartment, then you are far less likely to be charged for leaving drywall anchors in the wall but they will charge you for a large hole. Although some places may still end up charging you to fill in any holes even if you used dry wall anchors. I used a ton at my last place and they gave back most or all of my deposit.
If you are fine with them being metal, then it isn’t hard to remove the cap on the ones I linked and then remove the foam, but I’m sure other options are available that don’t have the foam at all.
I 3d print my own for cheap cheap :blush:
https://store.rossmanngroup.com/atten-862.html
Turnigy SK8 motors for 60$
https://a.aliexpress.com/_mqqNlk2
:rofl::fire:
On the real, I got one of these electric screwdrivers for Christmas and it’s super handy for small inside jobs. Only say inside jobs because all the big tools are already outside. Even worked for softwood screw driving. Adjustable torque steps that make sense. Light to illuminate your work and $50 right now. Takes normal hex shaped bits and I like it.
Fanttik Cordless Screwdriver Kit 14pcs, Digital Screen, Li-ion 2000mAh, 6 Gears 0.5-6 Nm Rechargeable Electric Screwdriver Set 3.6V with USB Cable, Front LED, Grey - NEX L1 Pro https://a.co/d/cRmFJJr
These are cheaper and do the same thing as well as all the others. But they are very handy, I agree.
Gtfo with your German Ebay-saussenkringlebummen! Last time I clicked one of those links, it took me weeks to get it to default back to English.
That’s how I feel about all the American-I-carry-more-guns amazon links. Don’t fuck with my localization.
